Home > Technical > rear view mirrors dip?? HELP!! |
You don't need to "set" them, they just do it if the system is working OK!! You can download the owners manual for your model year in PDF format from the Land Rover UK website. Sounds like a trip to a dealer might be needed to trace the fault 2020 Pangea Green 1st Edition D240 New Defender 110 is here and loving it
Mon Mar 01 2010 11:13pm |
tornado34 Member Since: 06 Dec 2009 Location: London Posts: 242 |
Tim, sorry to disagree, but there is a personal preference setting throught the 'i' button - with the ignition on, but engine off, press the end of the left had stalk to access tyhe 'i' settings - step through with the controls on the right hand side of the steering wheel. This gives you many options including reverse mirror dipping (which I have to say I turned off as I need to miss the gate posts when I reverse out of my garage!)
Mon Mar 01 2010 11:25pm |
Well there you go, mine have always worked and I have never needed to do anything to them! I would prefer it if the driver's side didn't dip but there you go. Sorry for the misleading info must get the manaul out again sometime! 2020 Pangea Green 1st Edition D240 New Defender 110 is here and loving it
Mon Mar 01 2010 11:52pm |
Also just remembered, if when you are in reverse and the mirror's have dipped, if you adjust them whilst still in reverse and set your drivers seat memory they will be remembered. Therefore, just adjust your drivers mirror to 'normal' when in reverse and you should fix your wish Tim |
Mon Mar 01 2010 11:56pm |
NasMan Member Since: 06 Jan 2010 Location: West London Posts: 102 |
The only way to remember the setting is to set them whilst the engine is OFF in position II. An then save memory position. The next time you select reverse when the vehicle is on, the mirrors will dip to the correct position.. Tim - you can use the same technique to NOT have the driver's mirror dip, as they can be set indepedantly.. 57 RRS | TDV8 HSE | Java Black | Black Interior | Side Steps | 20" Alloys Bought in Januray 2010. Colour Coded Car with Forum Members Help. CURRENT - 2004 Mercedes SL350 | Silver - Best Car I have ever had GONE - Jaguar S-Type | Silver |
Tue Mar 02 2010 1:27am |
Bradders Member Since: 08 Oct 2009 Location: Leeds Posts: 2515 |
Just tried this myself as both mirrirs dipped when reversing - very off putting. I adjusted the drivers mirror back to its normal position while in reverse, selected memory one and its has stored the adjusted mirror position so when reversing, the drivers side mirror doesnt move but the nearside does, so I can see the kerb. FF 4.4 V8 Soooo looking forward to this bad boy
Tue Mar 02 2010 6:55pm |
Weird thing is - I think it was Tim that told me in the first place... Maybe he is less steady when he is on terra firma..? 57 RRS | TDV8 HSE | Java Black | Black Interior | Side Steps | 20" Alloys
Tue Mar 02 2010 7:02pm |
Lol, memory is failing with advancing age! 2020 Pangea Green 1st Edition D240 New Defender 110 is here and loving it
Tue Mar 02 2010 7:13pm |
x5pea Member Since: 03 May 2007 Location: Lanarkshire Posts: 2097 |
i tried that and it didnt work so i just switched em off |
Tue Mar 02 2010 7:58pm |
