| Home · FAQ · New Posts · Private Messages · Search · Members · Members Map · Calendar · Profile · Donate · Register · Log In |
![]() | Home > Technical > Rain sensing/auto wipers |
| RRUK Joined: 10 Jun 2005 Location: Certainly In-Vogue Posts: 2225
Obviously I don't have the car yet or the manuals but I had rain sensor in the BMW, and the way they worked was that if the wiper stalk was in the intermittent position when you insert the ignition key the wipers will be set to auto, whereas if you return the wiper stalk to position 0 before starting up and then subsequently put the wipers onto intermittent, the auto feature was disabled.
| d3matt Joined: 12 Jul 2005 Location: Oxfordshire, UK Posts: 729
On the Sport, when you put the wipers into intermittant, then they are in auto mode. You do therefore not have an intermittant feature if you have auto wipers. Matt
| Simon Joined: 13 Jun 2005 Posts: 44
The adjuster on the stalk is for the rear wiper intermittent interval, not for the sensitivity adjustment of the rainsensing front wipers......according to the manual. |
| MDP Joined: 15 Jun 2005 Location: Back in an AUDI Posts: 8560
This morning I used my wipers for the 1st time ( i only picked the car up on friday ) as I needed to clear the front screen so pulled the stalk for a quick single wipe..... only to find it did this plus the rear wiper also gave a single wipe? I only wanted to wipe the front screen & not the back as that was clear(ish) and didnt want to wipe dirt over the rear screen |
| Andrew Joined: 16 Jun 2005 Location: Cheltenham Posts: 48
flick the switch downhill and you get a single wipe of the front wipers. i agree the auto wipers are a bit useless but will just have to put up with it.. |
Cheers guys, its just getting used to the different actions" the stalk " utillises............old habits die hard |
| caporajm Joined: 25 Jul 2005 Location: Austin, MN Posts: 55
So to add on to this.. what about the headlight washers.. how do you turn them on? RRS S/C Special Edition, Vesuvius |
| Biggles Joined: 26 May 2005 Location: Preston, Posts: 916
The headlamp washer only becomes active when the headlights are switched on and work every fifth wash of the windscreen/windshield. Its out there somewhere. Second V10 Treg on the drive at the moment. |
aaahhh...Life's rich tapestry !
Simon, you're right. I drove it in the rain tonight and after playing with the adjuster, I accidenlty found that it was in fact adjusting the delay of the rear wipe - from 4 seconds to 13 seconds. Yet, my manual says it adjusts the sensitivity of the rain sensor on the front. Well, I'm happy now that I know it is actually doing something! Matt
