Home > Technical > Parrot Bluetooth kit
WOODY179
A neighbour has just bought a 2006 RRS HSE, he was told that it had a phone kit but it doesn't (even though it does have the roof mounted aerial Confused ) so I believe the best thing to fit would be a parrot kit, maybe the CK3200. Has anyone else fitted this and if so where have you fitted the control unit? Pictures please.
It might have belonged to a member on here as it had 3 wheel caps with black LR badges and one where the badge had fallen off.
Post #251907 Mon Jan 25 2010 9:57pm
Tim in Scotland
I had a Parrot handsfree system in my last RRS which was an SE so didn't have the satnav so the display unit was fitted in the space for the nav screen and the wiring disappeared neatly into the back of the dash out of sight. If you use the search function you should find a few pics of it from about 4 years ago. The roof aerial is the satnav antenna IIRC as I also had one fitted to cover the 'orrid plastic strip on the roof where the aerial should have been! Folks say that the roof aerial is the phone antenna but it isn't - GPS requires a clear horizon to be received well so the roof is the best place for the antenna!
My Parrot was fitted by the local Land Rover dealer who was able to integrate it with the radio so I had the muting when there was a call. 2020 Pangea Green 1st Edition D240 New Defender 110 is here and loving it
Post #251915 Mon Jan 25 2010 10:23pm
flydive
I had a Parrot 3100 in my old TDV6
Here is the picture
 '08 RRS TDV8
Post #251917 Mon Jan 25 2010 10:37pm
Tim in Scotland
That's the same model as I had , mine was mounted in a similar place but on the right side of the car.............. 2020 Pangea Green 1st Edition D240 New Defender 110 is here and loving it
Post #251919 Mon Jan 25 2010 10:39pm
2nd Rower
Australia 2008 Range Rover Sport TDV6 HSE Chawton White
This is where I have mine:
Justcarkits.co.uk supplied the cable so that the radio mutes and the phone call comes through the speakers! They were very helpful on the phone with advice.
It is secured to the dash with a piece of velcro! Whistle The microphone is at the top of the A pillar.
Post #251922 Mon Jan 25 2010 10:53pm
Landlord
United Kingdom 2010 Range Rover Sport 3.0 TDV6 HSE Alaska White
Just bought the Parrot 3200 for the wifes car does the velcro hold the display securely ? MY10 TDV6 HSE, Alaska White, Ebony with Contrast, Park Heat, Paddle Shift, Privacy, Heated Steering Wheel, Extended & Premium Leather,
MY07 TDV6 HSE, Zermatt Silver, Gone
1964 Austin Healey 3000
2007 LR Defender
2011 VW Tiguan R Line
Post #251924 Mon Jan 25 2010 11:06pm
2nd Rower
Yes very securely!
It never moves, but if I needed to remove the unit, it would then be relatively pain free with no holes or marks in the dashboard!
Post #251965 Tue Jan 26 2010 10:26am
WOODY179
Thanks everyone Thumbs Up
Post #252211 Wed Jan 27 2010 5:38pm
