Home > Technical > Washer Jets.... changing angle of jet. |
SimonH Member Since: 18 Feb 2009 Location: York, North Yorkshire Posts: 54 |
For the last 25 years I have always changed the angle of washer jets onto the windscreen by sticking a pin into the jet to adjust until the desired angle is achieved.
Sun Jan 03 2010 5:17pm |
Thanks for the kind words Tim.....
Sun Jan 03 2010 7:41pm |
MAW Member Since: 06 May 2006 Location: Lincs Posts: 3104 |
Thicker pin can you not pull remainder out with pliers |
Sun Jan 03 2010 11:33pm |
No, it has broken flush with the opening (she said )
Mon Jan 04 2010 12:33pm |
The jet holder isn't iced up is it Simon? Provided it wasn't a stainless steel pin, have you tried using a magnet to remove the broken off bit ? 2020 Pangea Green 1st Edition D240 New Defender 110 is here and loving it
Mon Jan 04 2010 12:39pm |
C10CKO Member Since: 19 Sep 2007 Location: Amazingstoke Posts: 100 |
...or super gluing another pin to the snapped one... carefully pulling it out once they dried together. MY12 RRSport 3.0 SDV6 Autobiography
Mon Jan 04 2010 2:58pm |
purple people eater Member Since: 10 Dec 2009 Location: Miles beyond midlife crisis Posts: 990 |
what about a cordless drill and a 6mm HSS bit, may use a bit of water after and you will need to keep filling bottle up purple people eater
Mon Jan 04 2010 3:54pm |
OK I went to the local dealer to find out how to re-direct the nozzles as it isn't shown in the owners' manual...........
Fri Jan 08 2010 11:11am |
lespes Member Since: 16 Jun 2008 Location: Channel Islands Posts: 1052 |
Page 97 in manual
Fri Jan 08 2010 11:47am |
Endjin Member Since: 22 Jun 2007 Location: Aberdeenshire Posts: 2087 |
I had a similar problem. On on investigation it is just simply that the mechanism for moving the
Fri Jan 08 2010 12:01pm |
samd Member Since: 21 Sep 2009 Location: Derbyshire Posts: 118 |
Yeah but do we really need to know that your workbench needed adjustment? |
Fri Jan 08 2010 12:17pm |
@samd - 2013 Discovery HSE Luxury - 3.0 SDV6 - Santorini Black
Fri Jan 08 2010 3:39pm |
Pelyma Member Since: 29 Sep 2005 Location: Sussex Posts: 1497 |
The jets are only about £10 the pair and take minutes to change Porsche Cayenne S Diesel 66 Plate |
Fri Jan 08 2010 5:53pm |
