Home > Technical > Help With Nav |
Jimmy_75000 Member Since: 06 Oct 2006 Location: London, UK Posts: 1146 |
Depending of the year of your car, you might not be able to input destination while driving...If it's all working when you are at a stop and not when in motion, then you have your answer... Range Rover Vogue ‘17 TDV6
Mon Nov 23 2009 9:03am |
x5pea Member Since: 03 May 2007 Location: Lanarkshire Posts: 2097 |
ah good shout jimmy al pop outside and check mate |
Mon Nov 23 2009 9:05am |
OK i feel stupid now |
Mon Nov 23 2009 9:14am |
It happen to every one! Think you might be able to do an upgrade that will allow the input on the move mode...Worth waiting for someone else on the forum to tell you how... Range Rover Vogue ‘17 TDV6 Gone: Range Rover Vogue '11 4.4TDV8, Range Rover Sport ‘59, Range Rover Sport ‘56 |
Mon Nov 23 2009 9:47am |
joka748 Member Since: 28 Nov 2007 Location: Hampshire Posts: 63 |
x5pea
Wed Nov 25 2009 7:55am |
MAW Member Since: 06 May 2006 Location: Lincs Posts: 3104 |
There is also a workaround via a hidden button top centre of nav screen with a pin option to get into nav on move (and other stuff) it works but is a pain to enter every time you startup |
Wed Nov 25 2009 9:52am |
