Home > Maintenance & Modifications > fitting brembo's |
R33 Member Since: 14 Jun 2008 Location: Marlow Posts: 193 |
Yes you need the disc back plates, they are cheap any easy to get from a LR dealer. I got mine in 24hrs from CHPR. You might also need the Brembo brake wear sensor easily bought on eBay or from a dealer. Then you should be good to go. |
Tue May 12 2009 1:47pm |
kedz Member Since: 10 Apr 2009 Location: manchester Posts: 151 |
thank's for the info mate |
Tue May 12 2009 10:31pm |
Jonathan Member Since: 11 Jan 2008 Location: York Posts: 434 |
Kedz
Wed Jun 10 2009 1:01pm |
Mine are gloss black so they look a little more bling
Wed Jun 10 2009 1:56pm |
Liking your gloss black idea but not going to mess with mine til they need replacing again - agree the braking is 2nd to none.
Wed Jun 10 2009 9:47pm |
Just looked at the spec of your car for the first time and I'm a bit confused
Wed Jun 10 2009 10:49pm |
Yep - it has but they are the grey ones with black writing and I want RED!!!
Fri Jun 12 2009 2:03pm |
simonsi Member Since: 01 Dec 2006 Location: Leicester Posts: 259 |
They make a great D3 upgrade too..... Cheers
Fri Jun 12 2009 9:04pm |
Adam RRS Member Since: 19 Nov 2008 Location: St. Albans, Hertfordshire Posts: 567 |
are the range rover and the range rover sport ones the same?
Fri Jun 12 2009 9:07pm |
I´ve not compared but have seen some comments that they may be subtly different.... Cheers
Sat Jun 13 2009 8:09am |
Nope they are not compatible with the RRS and there are several different types for the the L322. |
Sat Jun 13 2009 2:36pm |
also i heard if you upgrade from standard TDV6 calipers to TDV8 brembos, you need to change the hubs too. is this true? WINNER - 2009 Best in Class Range Rover Sport Award
Thu Jul 23 2009 10:12am |
