Home > Maintenance & Modifications > Side steps problem
UB
Australia
Side steps problem
Hey all, have run into a problem installing a set of 2nd hand side steps.
The steps didn't come with new side sills, so I told the panel beater who are fitting my steps to cut into the current sills. While the steps bolted on fine, they noticed there is a grove that runs along the inside of the sills, which they rekon will get in the way of the new bolts holding the steps.
To me, its looks like the bolts might clear the protruding grove, but only just. Has anyone run into such problems!?
Confused
Post #227305 Thu Jun 04 2009 1:18pm
terrieremery
England 2011 Range Rover Sport 3.0 TDV6 HSE Santorini Black
ill be interested in this because ive got the same job to be done and sills are not available,i wonder if you could substitute the bolts for dome torx screws with a lower profile
Post #227314 Thu Jun 04 2009 4:09pm
IanR
Hi there UB... In reply to your message there is NO problem, the bolts heads sit above the 'grove' . . . I fitted a second hand pair and simply cut the existing sills with a hot wire, it took some time ensuring they were cut to the right fit now all fit perfect and looks GREAT Very Happy . . . . Drop me a line if you require further information . . . Thumbs Up
Post #227326 Thu Jun 04 2009 9:10pm
filaborg
I have just bought and fitted some new side steps and they did not come with a replacement plastic sill. Instead they supplied a paper template so i had to use my existing sills, a little time consuming but i got there in the end.
Your a little Censored if you have no template though.
Post #228020 Fri Jun 12 2009 8:24pm
