Home > General > Discs and pads |
mlines Member Since: 10 Dec 2006 Location: UK Posts: 480 |
I know you claim to have zero technical knowledge but changing the discs and pads should be a straight forward job.
Tue Jul 08 2008 6:07pm |
MAW Member Since: 06 May 2006 Location: Lincs Posts: 3104 |
You get the squeal then the light IME - DIY is possible and a third of LR price - doubt discs are really needed.... |
Tue Jul 08 2008 8:39pm |
simonsi Member Since: 01 Dec 2006 Location: Leicester Posts: 259 |
There is a pad wear sensor on 1 front pad and 1 rear pad only. The other three pads on each axle can wear right down to the metal and you won“t get a warning light.
Tue Jul 08 2008 10:18pm |
bermyandy Member Since: 09 Sep 2007 Location: London Posts: 336 |
shes on about 28k miles - only had it for 6k miles, waiting to speak to the dealer tomorrow to ascertain if these are original discs etc |
Tue Jul 08 2008 10:44pm |
PauloAmore Member Since: 27 Jan 2007 Location: Bonnie Scotland Posts: 1289 |
My SC discs were changed at 20k FYI. 2022 P440e AB |
Wed Jul 09 2008 10:49am |
Hmm so either these are all original or else she's got through two sets of pads and possibly two sets of discs, but then if she had approx 16-20k out of the first discs and pads she would have only done 8-10k on the second... Doesn't sound quite right so I'd guess those are original discs and possibly 2nd set of pads, in which case you may well be due discs and pads together now. Front discs are a doddle to change but do need 4 VERY tight bolts removing and replacing to take the calipers off (2 bolts per side). I'd find it hard to justify more than 1hr labour + the parts (pads are £100 + vat per set) so find out the parts prices and cost the job accordingly. Cheers Simon 2007 2.7HSE 20" Wheels 2005 TDV6 D3 S Auto - Zambezi Silver - JE Tune - RRS 19" - Sidesteps - Roof Rails Body Side Strips - Xenons - Bright Pack - Cold Pack - Premium Stereo Alpine Roof - Towpack - Alpine Touchscreen Satnav - Veba Rear DVD changer Alpine Roof Monitor - Webasto FBH Timer - Brembo Frt & S/C Rr Brakes |
Wed Jul 09 2008 12:11pm |
