Home > Maintenance & Modifications > Wing mirror glass
pgwright
2006 Range Rover Sport TDV6 HSE Zambezi Silver
Wing mirror glass
Hi, anyone know the best place to get a new wing mirror glass as i had the misfortune to have mine clobbered by a white van man!! Censored Rang landrover and they quoted me 30 quid!!! Bit expensive me thinks1
Post #148212 Thu Dec 13 2007 9:31pm
Josh
Dealer and get them to fit it as it's a real pig Exclamation
If you try it yourself you will probably break another glass trying to do it. If dealer breaks it they will pick up the bill and not you Idea
One or two of us have had the experience Wink TDV6 - gone
TDV8 - gone
Post #148231 Thu Dec 13 2007 11:19pm
NZHereIam
New Zealand 2006 Range Rover Sport TDV6 HSE Zermatt Silver
I had the misfortune to awake one morning to find the Audi wing mirror located on the road instead of on the car, I purchased a ne mirror and mirror housing , tried to fit it myself, broke both the mirror & the housing and subsequently went to the dealer, paid 245 quid, yes 245 quid, and got him to do it!!!!
Not a happy chappy at that point Big Cry If you dont live on the EDGE, you are taking up too much space!!!!!!!!!!!!!
06 RRS HSE ( in Wellington Dockyard, still waiting for release!!)
05 Jeep Cherokee LTD Edition
Post #148235 Thu Dec 13 2007 11:25pm
Yep that's about right for the glass. I went through a couple myself.
And Josh is right - DEFINITELY get them to fit it, it's more luck than judgement to get them on.
Post #148256 Fri Dec 14 2007 9:39am
chrisg
Best bet is main dealer - £30.53p incl VAT - just bought one.
The mechanic there showed me the trick to fitting the new glass without breaking it ...... Very Happy
1. Push the black plastic ring inside the mirror assembly at the bottom as far as it will go dwn (i.e. so if the mirror glass was attached, it would be pointing down at around 45 degrees).
2. On the back of the mirror glass, you will see that the top of the corresponding black plastic ring has two clips in the corner that clip over the top of the inernal ring. On the bottom of the mirror glass there are 2 small and 1 large clips. Now connect the heated mirror wires before you go any further.
3. Slide the mirror glass over the top of the internal ring so that the corner black triangular clips (above) are seated over the two lugs and the mirror supports itself.
4. Now push the mirror downwards so that the mirror glass is in line where it should be, but still protruding.
5. GENTLY push the centre bottom of the mirror glass inwards so that the 2 small and 1 large clip slip into place (a little clicking sound should be heard when it is seated properly).
6. Er ... that's it.
7. Now remove the mirror glass again and connect the heated mirror wires that you forgot to connect in step 2.
8. Clean grubby finger marks and test electric movement.
9. As Gordon Ramsay would say ... "RRS Wing Mirror Glass Replacement - Done". (Or even F Censored ing Done).
Clearly I don't take any responsibility for broken mirror glass, in case there are any lawyers reading.
Wink TDV8 RRS
Aston DB9 Volante
Subaru Legacy Spec B
and a Nissan GTR on order ! Can't wait.
Post #173740 Fri Jun 20 2008 6:47pm
Rather you than me.... Laughing
Post #174024 Mon Jun 23 2008 11:52am
acowx
United States 2006 Range Rover Sport Supercharged Rimini Red
Does anyone have any pictures of the mirror housing (motor) with the glass removed ?
I want to take the glass out and replace the motor but for the life of me I can't see any clips that are referenced in this thread...
And no, I'd rather do it myself that take it to LR Smile
Thanks
Post #256749 Sun Feb 21 2010 11:41pm
acowx
Seemingly detailed instructions are in the LR3 Workshop Manual, anyone care to post it for me ?
Smile
Post #256753 Sun Feb 21 2010 11:56pm
Landlord
United Kingdom 2010 Range Rover Sport 3.0 TDV6 HSE Alaska White
And again get dealer to do it.
Had one break a couple of years ago. £25 for the mirror, LR mechanic struggled to fit it so I wouldnt bother if I were you ! MY10 TDV6 HSE, Alaska White, Ebony with Contrast, Park Heat, Paddle Shift, Privacy, Heated Steering Wheel, Extended & Premium Leather,
MY07 TDV6 HSE, Zermatt Silver, Gone
1964 Austin Healey 3000
2007 LR Defender
2011 VW Tiguan R Line
Post #256764 Mon Feb 22 2010 9:42am
Couldn't agree more - if you try and do it and the glass breaks, you'll need to buy another one. If you get LR to do it and they break it, then you won't Thumbs Up
Post #256769 Mon Feb 22 2010 10:22am
acowx
Again, I'm willing to take the risk, anyone got the docs available for me ? Smile
LR3 forum suggests that detailed instruction are in the Workshop manual for the LR3.... anyone.... ?
Post #256811 Mon Feb 22 2010 2:17pm
purple people eater
You are a brave man, IIRC you have to press really hard on the glass to get it to clip in, wear gloves! purple people eater
There are no good days, just some days that are not as bad as others!
Gone RR 4.0 P38 Autobiography MY99 Red ( Evil or Very Mad money pit)
Gone Big Cry RRS MY06 2.7TDV6 HSE Rimini Red
Gone RRS MY10 3.0TDV6 HSE Bali Blue with lots of bits (never grew to love it)
Here Now - 3.6 TDV8 FFRR OVERFINCH Stornoway Grey - loving it x
My work car Ford Mondeo 2.0 TDci Zetec auto Estate in Silver
Post #256814 Mon Feb 22 2010 2:33pm
You could ask on the D3 forum if they have a copy uploaded anywhere?
Post #256828 Mon Feb 22 2010 3:20pm
1JBS
United Kingdom 2012 Range Rover Sport SDV6 SE Orkney Grey
Just sucessfully fitted a new mirror glass to the N/S mirror housing thanks to the guide on this thread Thumbs Up What would we do with out RRSport.co.uk Very Happy
Post #353200 Wed Aug 08 2012 5:31pm
