| Home · FAQ · New Posts · Private Messages · Search · Members · Members Map · Calendar · Profile · Donate · Register · Log In |
![]() | Home > Technical > Damn warning pinger !!! how the hell can I deactivate it ?. |
| dadanek Joined: 30 Mar 2008 Location: Czech republic, Pecky Posts: 44
Well... I know... Use big hammer... Believe me - It will help you |
| shmoogle Site Moderator Joined: 07 Sep 2005 Location: Me fail English? That's unpossible. Posts: 19061
Unfortunately, I don't think you can turn that off.... |
| JSI Joined: 14 May 2008 Location: Perth Posts: 13
I Like the Hammer idea |
I realise the warning tone is there for a reason & also how complex it's integration is, if you indicate & remove your seat belt, the warning bong cancels out the indicator click, then when the 7 bong cycle finishes, the indicator click continues.....hhmmmm. It does sound like pulling the dash off & stuffing blue tack in the little speaker is the only answer. Perhaps I'll try that with my wife first & see if it has the desired effect before I tamper with my Rangey 08 TDV6 stornaway alpaca Chipped overfinch tiger & happy ! |
| Very Annoyed Site Moderator Joined: 23 Aug 2005 Location: bat-wielding monkey-spanking tough-love zero-tolerance Euro-sceptic moderator - So just watch it! Posts: 14414
Well, he is from Oz |
Come on guys.....you should have guessed that if i own a Range rover & live in Perth........I Must be English......with a tan ! 08 TDV6 stornaway alpaca Chipped overfinch tiger & happy ! |
| Jonty Joined: 11 Mar 2008 Location: Doncaster Posts: 97
Are proper australians not allowed an RRS ??
Well, As you will probably know, Proper Aussies are the black fella's that still live under trees so the answer to your question is no. The 4x4 market is a tough one over here, most are die hard Landcruiser fanatics, probably because if you break down in the middle of the bush, your more likely to find someone with a Landcruiser near by than a RRS.........idiots I say ! Mind you....I did blow my turbo the first day !...so maybe they're the smart ones .......I'll say no more 08 TDV6 stornaway alpaca Chipped overfinch tiger & happy ! |
So are you saying the in/out method doesn't work for 2008+ and only the dealer can do it? |
Yes that's correct, the trouble I found was in all the other posts, they said to sit in the car, ignition on etc etc & eventually the red man would disappear & you could then do your in/out.....stuff, well, according to the dealer who I discussed this with (after trying several time) said........totaly new computer set-up in the 2008 model, more flexibility to personalise....to a degree & a few glitches rectified (like the ability to disable the seatbelt warning on your own......he said ! but he was more than happy to disable it ....at no charge !!!! unheard of I thought, Mind you, it was in for it's first service so I was still paying him....in other ways. 08 TDV6 stornaway alpaca Chipped overfinch tiger & happy ! |
Thanks for the info, I didn't know this |
I've just realised something & come over in a cold chill........I'm believing my dealer !!!!, I need to sit down a minute, I feel feint........ 08 TDV6 stornaway alpaca Chipped overfinch tiger & happy ! |
