Home > General > Open boot to change a tyre? |
PauloAmore Member Since: 27 Jan 2007 Location: Bonnie Scotland Posts: 1289 |
I bought a new Conti at the weekend as I had a slow puncture and the old one was nearly done. Anyway, both Kwik Fit and National said I needed to open boot and one thought I needed to put the hazards on to stop the suspension going nuts. Well, she still went into super off road mode, but I thought it weird that both mentioned it. Is it true?
Tue Mar 25 2008 7:59am |
Kaine Member Since: 27 May 2006 Location: Hills of Shropshire Posts: 8902 |
no - not with mine anyway |
Tue Mar 25 2008 9:19am |
nigelkippax Member Since: 29 Jul 2006 Location: Glasgow Posts: 19 |
Went to Kwik Fit last week-end with the biggest bolt in the world through my tire. They said the same thing about opening the boot. It worked!!! Must read my manual more!!! |
Tue Mar 25 2008 9:17pm |
Steve in germany Member Since: 15 Nov 2007 Location: Bad Lippspringe Germany Posts: 980 |
Just lock it in Access should do the job, My Q7 had a jacking mode that you had to select via the MMI before you could go anywhere near it. Speed Limits! not where I live!
Tue Mar 25 2008 9:25pm |
PJPR01 Member Since: 12 Mar 2006 Location: Houston, Texas Posts: 355 |
Opening any door, including the rear one should stop the suspension from going up and down under normal circumstances, e.g. if you have pressed the suspension lower button, but open the door half way through the process, it will stop the suspension from proceeding any further.
Tue Mar 25 2008 9:29pm |
Pretty sure the manual says to put it in off road mode, not access.... 2022 P440e AB |
Tue Mar 25 2008 10:17pm |
Alicatt Member Since: 11 Jun 2007 Location: Eating in Eksel or Ice cold in Alex Posts: 1435 |
puttin on the 4 offroad wheels yesterday I had the boot open and in access hight, the car still tried to self level and keep the wheel in contact with the ground, do yourself a favour and put it in offroad hight, although the car is higher you have to jack it up less Sons of dogs come hither and get flesh
Wed Mar 26 2008 9:52am |
Hmm, don't remember them ever doing that with mine (and it spent a good few visits at the tyre place).... but I guess as time has passed, the fitters have learnt all the tricks
Wed Mar 26 2008 10:10am |
