Home > Technical > Accessing N95 address book via BlueTooth |
MDP Member Since: 15 Jun 2005 Location: Back in an AUDI Posts: 8598 |
OK - so I can now happily confirm that the software I have insatlled on my Nokia N95 [ see beginning of thread] works 100% OK in the RRS... I tried it today at the Coventry meet in Josh's RRS ... within less the a minute I had my full phonebook in his car over bluetooth
Sun Nov 18 2007 6:07pm |
j8keyboy Member Since: 09 Oct 2007 Location: Loughborough Posts: 37 |
MDP - I've just downloaded the contacts app to my N95 and started the app and it just says 'Processing' for ages - is this perhaps due to the 300 or so multiple contact entries stored on my phone? What exactly happened when you transferred your numbers over?
Tue Nov 27 2007 11:44am |
With a 2005 RRS - you may need to get the software/firmware update done on the bluetooth system at your local LR dealer
Tue Nov 27 2007 12:54pm |
I've already got the latest software/firmware update on my RRS. I get the 'Processing' message for ages even when I'm not even connected via Bluetooth to the car Bluetooth. How may contacts do you think you transferred over? |
Tue Nov 27 2007 1:13pm |
Not sure? but must be in the region of around 150 - 200 plus .... I get each contact with a seperate entry for mobile - home - business etc .... so even more entries when they appear on the RR Sports screen.
Tue Nov 27 2007 1:43pm |
It sounds as though the no. of entries shouldn't be an issue then - I'll give another try later and if not, as you suggested, just try with 1 entry. |
Tue Nov 27 2007 1:59pm |
Either that ...... or get your LR dealer to re-check the software / upgrade that they say they have done. The factory software upgrade is supposed to give you the same level of bluetooth connectivity as a new 08 model year or even the newly 08.5
Tue Nov 27 2007 4:06pm |
I had the factory upgrade done about 2 weeks ago though so that was before the new TSB00095...29/10/07 bulletin.....DOH unlucky for me!!!! I tried the contacts push again but it still just hung - I will try with just one contact hopefully tonight......I really hope I can get this working as opposed to spending £100 or so for the stealer to update the Bluetooth again! |
Tue Nov 27 2007 4:47pm |
I think its sounding more like a software re boot/upgrade is needed
Tue Nov 27 2007 4:58pm |
But if I've just recently had the RRS BT updated and my N95 is all up-to-date then surely this should be working as my RRS software version is probably the same as Josh's TDV8 is it now? |
Tue Nov 27 2007 5:19pm |
I would have thought so - thats the whole point of the software upgrade
Tue Nov 27 2007 5:24pm |
What was the exat software version of the N95 - you can obtain this by typing: *#0000# |
Tue Nov 27 2007 5:38pm |
Mine is V11.0.026 17-04-07 RM-159 Nokia N95 [65.01]
Tue Nov 27 2007 6:07pm |
JayMann Member Since: 19 Jan 2006 Location: Stop acting like snob when you just won the Lotto! Posts: 22898 |
Mine is v12.0.013 i have the latest version
Tue Nov 27 2007 11:00pm |
sid Member Since: 21 Aug 2007 Location: northants Posts: 45 |
Version 20.0.015 released 26/11/07
Wed Nov 28 2007 1:08am |
