Home > My Range Rover Sport > FINALLY!! Just got my RRS S/C *pics*. Also please help..pg2
Evolved
shmoogle wrote:
Evolved, your tinted glass.... is it the factory fitted glass or an aftermarket tint? Question
factory fitted shmoogle Cool RRS S/C...privacy glass,side steps and sunroof
Post #115293 Tue Jun 12 2007 12:36am
Are you absolutely sure? Seems your aerial is very visible... a classic identifier that it's an aftermarket job Confused
Post #115370 Tue Jun 12 2007 9:00am
United Kingdom 2005 Range Rover Sport TDV6 HSE Zambezi Silver
Sorry to burst your bubble but the tints are not factory fitted - they may have been fitted in a factory but not in Solihull! RRS 2.7 TDV6 HSE Zambezi silver,Alpaca.
On Order - LRX expected 2010
Post #115437 Tue Jun 12 2007 11:21am
Evolved
Hmm.....I could be wrong...
How can you guys see the difference? RRS S/C...privacy glass,side steps and sunroof
Post #115463 Tue Jun 12 2007 12:28pm
From the rear side windows where your diversity aerial is sited... on normal glass which gets an aftermarket tint applied you can see the aerial very visibly. The factory fitted privacy glass is actually coloured glass (i.e it's not a film) so the aerial is buried away inside the glass so you can't see it...
Post #115467 Tue Jun 12 2007 12:32pm
A much better explanation than mine! Wink
Post #115469 Tue Jun 12 2007 12:35pm
Tim in Scotland
You beat me to the answer shmoogle.
Just looked at my non privacy glass car - the antenna is actually bonded to the inside surface of the glass - as S says the privacy glass is coloured glass so the antennae don't show, with the aftermarket film this is laid over the top of the antennae wires and trap a small amount of air and are much more visible as a result A Carbon Footprint is the mark a lump of coal makes when it's dropped on the ground.
Tata TDv8 HSE - Stornoway/ebony and straight grain walnut with towpack, Tasmods and an HST grille. Coming soon LEDs in the headlights
Staying - Epsom Green Defender 90 for playing off road
Post #115470 Tue Jun 12 2007 12:35pm
Evolved
I hear ya!
Never really noticed it like that RRS S/C...privacy glass,side steps and sunroof
Post #115484 Tue Jun 12 2007 1:06pm
Tim in Scotland
Did you specify the factory fitted privacy glass E? If so then you could reject the car as not being the right spec? A Carbon Footprint is the mark a lump of coal makes when it's dropped on the ground.
Post #115487 Tue Jun 12 2007 1:08pm
Evolved
Speaking of this......I have another concern that is far more important to me....I was going to post a new topic but I'll just put it here anyways.
When my father's friend bought the vehicle he used it for a bit...Just a couple runs...since we were still trying to get some import licenses in order on our end. This took more time than we thought! When we finally thought everything was in order, we gave him the okay to ship it out. He did and when it got here, our local customs agent said that we needed more approvals!
This took me over 2 months! Paid alot of rent at the port storage facility etc.
Anyways long story short, after finally getting it off the port, I encountered a battery problem. It started once then cut off the next time and refused to start again.
So a couple days later I take it to the ONLY local authorized dealer here to replace the battery. They did, and everything worked fine. Brilliant I thought!
Now....time to pay the dealer's bill!...I see a ridiculous cost for the labour to replace the battery..£100!!!!
In Trinidad....that's madness! For hell's sake I could have installed the bloody thing myself!
I questioned as to why the labour cost on a simple battery change was so much.
Their answer/explanation was.....that any car that isn't bought through them will pay a higher parts and labour charge. The manager said that this was their policy since we didnt buy it through them but instead imported it on our own. He said if the vehicle was bought from them then the labour charge would have been £50 instead!......So I had to pay double? why!?!
Thing is...I also have a C class which I imported new directly from Germany and the firm here services it and honors the warranty just as they should. Labour and parts prices are the same as if I had bought it from them.
So why is Land Rover in Trinidad doing this to me? I figure it's because they are basically a monopoly here.
I intend on reporting this issue to a higher authority....but can someone direct me to where? RRS S/C...privacy glass,side steps and sunroof
Post #115529 Tue Jun 12 2007 2:28pm
E - they do it because they can. Each countries laws are different but I would contact LR in the UK to see what their policy re franchise costs is. They are probably an independent garage with the LR franchise and as you state you have no other choice so they basically can charge what they like - word of advice, don't piss them off too much because they could say 'sod you we never want to touch your car again' and then you will up stuck! RRS 2.7 TDV6 HSE Zambezi silver,Alpaca.
Post #115530 Tue Jun 12 2007 2:33pm
Hmm... I'm not sure but I think the LR warranty and service process is the same across the world.
You can raise issues with LR Customer Service in the UK directly, via email in the first instance to lradvice@landrover.com. They should be able to help you out further... good luck Very Happy
Post #115531 Tue Jun 12 2007 2:36pm
Forgot to say but I would have thought ALL warranty work should be free. I would also include a duff battery in that depending on the age of the car. RRS 2.7 TDV6 HSE Zambezi silver,Alpaca.
Post #115532 Tue Jun 12 2007 2:38pm
Evolved
Big Cry
you got that right.....
They already have that attitude of "take it or leave it"
Thanks VA and Shmoogle..will contact that email for some advice! Thumbs Up RRS S/C...privacy glass,side steps and sunroof
Post #115537 Tue Jun 12 2007 2:54pm
Evolved
It still has lots of warranty left which I would think should be honored anywhere. I'll email and when I get a response I'll post it up RRS S/C...privacy glass,side steps and sunroof
Post #115538 Tue Jun 12 2007 2:55pm
