Home > Technical > How to wire up the 2005 Adaptive Headlights in a Cherokee
dpwong
I bought a pair of RRS Adaptive Headlights to
install in a Jeep Cherokee.
Can anyone provide information on its
wiring and sensors to make them lights?
Parts No required for all parts to make them work
Thanks
Regards
dpwong
Post #104959 Wed Apr 25 2007 7:47am
Pelyma
You might be better asking this on the Disco3 site as they are of a more practical nature!
Post #104962 Wed Apr 25 2007 8:24am
Re: How to wire up the 2005 Adaptive Headlights in a Cherok
Thanks
Regards
dpwong
I'm presuming you know they fit etc.... might also be worth finding a J**p forum too and posting there too?
Post #104965 Wed Apr 25 2007 8:49am
ivery819
You might have a fair task in front of you. Shocked
My understanding is that the adaptive headlight electronic control module is connected to the Central Junction Box (main computer) by a proprietary Land Rover bus cable ................
I further understand that the signal sent out is derived from inputs of engine speed, road speed, steering angle, eas position etc, etc,etc.
I assume that this means that without CJB signals the Headlight module will not work.
Someone else may correct me on this. Big Cry
Post #104975 Wed Apr 25 2007 9:44am
Yep, let us know if/how you get any success with this Very Happy
Post #104980 Wed Apr 25 2007 9:52am
dpwong
Thanks for the information.
May be Hella electronic modules for Dynaview can be use to control the lights
regards
Post #104995 Wed Apr 25 2007 11:04am
Nutty Nige
United Kingdom 2009 Range Rover Sport TDV6 HSE Stornoway Grey
The problem you will have is the body control ECU, light control module, steering column angle module etc are way way different on a Jeep to an RR set up.
Not only are they different manufacturers but the board rate is different that takes the command between the ECU,s and its a whole different design.
To get these working correctly in a Jeep as they do in an RR would be a bigger task than one would first imagine.
Good luck with it. You don't stop playing because you get old, You get old because you stop playing.
07 TDV6 been and gone. 08 TDV6 been and gone. 08.5 TDV8 in evaluation mode and now gone. BMW 535D M sport Been and gone, Now time for RRS No4 - TDV6 HSE in Stornaway with Ebony - 09 Model 6 months old.
RS Cosworth 4x4 Stage 2 Mint for summer
Audi TT
Astra VXR for the daughter.
Post #105248 Thu Apr 26 2007 4:27pm
Tim in Scotland
I hope it doesn't all end up in a big torch! 2020 Pangea Green 1st Edition D240 New Defender 110 is here and loving it
Post #105250 Thu Apr 26 2007 4:36pm
ivery819
On reflection and in the light of more thought..... Laughing Laughing Laughing Laughing
You may be able to use the Hella module to give control in the horizontal only axis.
You would need to match the module output to the RRS control motors and work out some way of fixing the vertical axis movement inside the lamp unit.
This may have application for RRS owners who want to 'partially upgrade' their non adaptive lights.
Keep us informed Smile
BTW 'driller' on this forum did some work on this but he may have ended up only changing the bulbs.
Post #105408 Fri Apr 27 2007 3:40am
dpwong
Hi gentlemen,
Thanks for all the comments. Can anyone provide me information on wiring diagrams of the AFS. Which colored wire is for what purpose and their voltage. These may help in sourcing other ecu like from Denso.
Regards,
dpwong
Post #105638 Sat Apr 28 2007 12:25pm
ivery819
Try Here
and
Here
Post #105643 Sat Apr 28 2007 12:45pm
dpwong
Thanks for the diagrams.
Is there a parts cat. on the headlight assembly alone.
I found out that there are broken white plastic pieces. I need to buy them.
What is the part no of the central junction box & AFS ECU?
Are the AFS Modules under the lamp ECU?
Regards
Post #110002 Tue May 22 2007 6:38am
ivery819
dpwong
My parts diagrams show the headlights as one unit and then the part numbers are dependent on the VIN
No VIN then no part number.
Not much help
A visit to the local dealer is in order.
The ballasts and control units are mounted on and underneath the headlight units .
Not sure about the Control modules.
Someone else may know !
Don't be surprised if the CJB costs many thousands of pounds !!
Post #110003 Tue May 22 2007 7:08am
