Home > Technical > air suspension
RonnieG
air suspension
I use my air suspension quite a bit from raising it up to go into site or when at the point to points as i go into the field and drop her to access height for getting in and out for my wife and child. I have been told that I should not use it all the time is thins right if so should I look out for any problems or is this an old wives tale?
Post #164626 Fri Apr 11 2008 9:05pm
Tim in Scotland
If you use the compressore a lot (several 10's of times in a couple of minutes) then it will overheat but unless you are into those classic american lowrider cars then I think in normal offroad use the compressor gets far more use keeping the suspension/ car level than you can give it pushing the height adjust button. I remember over on Disco3 one of the Aussie guys reporting in the early days that the compressor overheated a lot in the outback driving on the corrugated road surfaces there 2020 Pangea Green 1st Edition D240 New Defender 110 is here and loving it
Post #164629 Fri Apr 11 2008 9:13pm
Josh
While we are on the subject of air suspension.
I note that the hand book dosen't cover what height the air suspension should be in when you are jacking it up to change the wheel ie. low/locked down, middle or high Shocked
You certainly can't do it in low/locked down because the wheels won't leave the ground. My tyres were changed in the high position so I hope that was ok Question
Anyone know the answer Question TDV6 - gone
TDV8 - gone
Post #164662 Fri Apr 11 2008 11:33pm
PJPR01
United States 2006 Range Rover Sport 4.4 V8 HSE Cairns Blue
In fact, the manual does say to have the car in off road mode prior to jacking it up. Look at the section under J for Jack!.
Also important to tell your local tire shop to do this as well if they are doing any work on your vehicle AND to jack it up from the frame, not under the suspension as some are wont to do.
Very Happy PJPR
Cairns Blue HSE
180k Miles of Adventure
Post #164666 Sat Apr 12 2008 3:11am
Bobby
Yes, it does...
http://www.rrsport.co.uk/gallery/albums/userpics/10024/Jack.pdf
at least in the MY06 manual.. Thumbs Up Malaysia Boleh!
4.2SC Chawton White, Stormers
Clear Side Repeaters, Towbar
Post #164667 Sat Apr 12 2008 3:17am
Alicatt
Belgium 2008 Range Rover Sport TDV8 HSE Buckingham Blue
Very Happy
While you have the wheel off the ground you can then get it into extended mode Thumbs Up Sons of dogs come hither and get flesh
Clan Cameron
Post #164716 Sat Apr 12 2008 12:56pm
Josh
Yes you are correct.
But it took me 3 reads of the tyre changing section to find it because it is so small. Didn't even get a mention in the index Exclamation
Personally I think it needs high lighting in the manual and not hidden a way. TDV6 - gone
TDV8 - gone
Post #164886 Sun Apr 13 2008 11:48am
