Home > Technical > Ipod question
cyberjes
2008 Range Rover Sport TDV8 HSE Buckingham Blue
Ipod question
does anybody know if ipod connection in RRS is compatible with the first generation ipod? MY08 TDV8 HSE
Buckingham Blue / Ebony / Lined oak / 19" Factory / Sunroof / Roof rail / Ipod Dock
Post #154914 Thu Feb 07 2008 4:02pm
Good question - I think it's compatible with all Ipods, although I'm not 100% sure. Someone will be able to confirm.
Post #154915 Thu Feb 07 2008 4:17pm
PJPR01
United States 2013 Range Rover Sport 4.4 V8 HSE Orkney Grey
If the first generation IPOD has a 3.5 mm female jack on it, plug it in via a wire with 2 3.5MM male ends...should be a cheap test to find out. PJPR
2017 FFRR TD6
Former LR: 2013 RRS, 2006 RRS
Post #155090 Sat Feb 09 2008 2:54am
Smarticus
United Kingdom 2005 Range Rover Sport TDV6 HSE Rimini Red
PJPR01 wrote:
a 3.5 mm female jack on it, plug it in via a 2 3.5MM male ends....
Sounds like some couples I know Whistle RRS TDv8 HSE Rimini
Disco 4 TDv6 HSE Ipanema
Defender 90, 200tdi CSW
Post #155096 Sat Feb 09 2008 10:23am
cyberjes
Laughing Laughing Laughing MY08 TDV8 HSE
Post #155102 Sat Feb 09 2008 11:45am
PJPR01
<OK---thatīs got to be a record...thread smartly derailed in 2 posts or less!
Very Happy Very Happy
<looking back though cyberjes, <i guess your question might have been could you use the first generation ipod in the audio connectivity module dock<- that <iīm not sure about since <iīm running a nano in the dock...havenīt tried a first gen there yet. PJPR
2017 FFRR TD6
Post #155110 Sat Feb 09 2008 2:35pm
cyberjes
/PJPR01
thanks for trying. Thumbs Up
i use nano (3rd gen) as well.
it's just that i do have a 1st gen ipod with bat problem that's lying around.
Just thought it'd be nice to be able to use it.
(or to use something that's actually made to fit the dock, if you catch my drift.)
cheers. MY08 TDV8 HSE
Post #155114 Sat Feb 09 2008 4:01pm
SachaR
Italy 2007 Range Rover Sport TDV8 HSE Java Black
I have a ipod photo 30Gb, it doesnt fit....... unless you remove the top clip as it is to thick to get in at an angle. I dont know if that helps.
Sacha RRS TDV8 HSE 2007- JAVA Black/Black interior,
UK BMW M3 CSL SB- now sold
1968 Innocenti mini
Post #155460 Tue Feb 12 2008 2:23pm
Alicatt
Belgium 2008 Range Rover Sport TDV8 HSE Buckingham Blue
there were a couple of adaptor plates came with the ipod dock, cant remember what they were for, they are still in the box at the house in belgium so cant have a quick look at them Sons of dogs come hither and get flesh
Clan Cameron
Post #155482 Tue Feb 12 2008 4:03pm
umbertob
United States 2006 Range Rover Sport 4.4 V8 HSE Chawton White
I found my 1st-gen iPod in a drawer tonight (remember when 10 gigs sounded positively ginormous?) Smile I tried to fit it in the ACM cradle, no way. The base of the cradle is just too slim to receive the thicker body of the original iPod, and the adapter provided only helps with smaller versions (Nano.) The manual for the ACM states that only 5th generation (and up) iPods are supported via cradle, so I suspect you may also run into software related problems if you could somehow manage to fit your old iPod in the docking cradle.
Post #155563 Wed Feb 13 2008 2:26am
cyberjes
/umbertob
that's exactly what happened.
i found out the hard way, as usual.
i forced-fit it into the cradle but just didn't work. MY08 TDV8 HSE
Post #155579 Wed Feb 13 2008 8:26am
Umbertob's right to get to all the function's on the ipod you have to use the docking cradle i.e track select, track name etc....
The 3.5mm jack in just for listening no function operation from here RRS TDV6 Gone but still around
Post #155582 Wed Feb 13 2008 8:31am
