![]() | Home > Maintenance & Modifications > TDV8 - too much torque? |
830Nm seems quite high in comparison to the stock 640Nm that it comes out of the factory with. I also seem to remember a previous post saying that ZF only expect the gearbox to be able to deal with torque ratings up to around 750Nm.... |
MDP Member Since: 15 Jun 2005 Location: Back in an AUDI Posts: 8598 ![]() ![]() |
But.. then who ever keeps a car for the life expectancy of its parts |
I suppose the trouble is, if your engine produces 800+ Nm and the gearbox is only happy with 750, then the potential for the gearbox to give up is greater.... at least I presume that's the case, I'm not a mechanic as most of you know |
Josh Member Since: 24 Dec 2005 Location: Here, there and everywhere Posts: 2054 ![]() ![]() |
If i was considering it I would stick to a LR specialist like JE. I'm sure there is a very good mechanical reason why JE have stopped at the figure they have quoted. TDV6 - gone
Indeed. Other tuning firms are available, of course |
PaulB Member Since: 10 Dec 2005 Location: UK Posts: 546 ![]() ![]() |
Mine is going in to JE on Monday for the same upgrades |
No, I'm sleeping with my Financial Director |
Steve in germany Member Since: 15 Nov 2007 Location: Bad Lippspringe Germany Posts: 980 ![]() ![]() |
I want mine done |
Cornelius Vermuyden Member Since: 15 Aug 2006 Location: The Far Canal Posts: 190 ![]() ![]() |
Further the topic of ZF gearbox capability in tuned TdV8 Range Rover variants raised by Chris and Josh and other posts here let me give members a very brief synopsis of why JE Engineering are confident of its mechanical integrity.The attained 800Nm is only 6.7% over the manufacturer's stated maximum safe input in the case of the 1st Generation box, and 4% in the case of the 2nd Generation. JE consider this to be well within any inbuilt safety margin. Having exhustively tested a considerably more powerful version in Germany, JE do not intend to offer any more powerful versions for sale than that presently listed. Interestingly, driving a Sport with the full-on test tune and unlimited, it is not the gearbox but the bodyshell that appears to want to shake itself to bits. B |
Colin,
Paul
ChrisH Member Since: 29 Dec 2007 Location: South West Posts: 46 ![]() ![]() |
I can get the exhausts done if I go down the JE route, so that is what I shall do |
