Home > Off Topic > I need help from a GEEK.
Page 2 of 4 <1234>
But a hub will be ok just to send info to the tills and the old back up at night when no one is here? RRS TDV6 Gone but still around
Post #151015 Thu Jan 10 2008 4:40pm
Yeah, I'm sure it will Thumbs Up
Post #151017 Thu Jan 10 2008 5:12pm
I hope so Confused RRS TDV6 Gone but still around
Post #151018 Thu Jan 10 2008 5:18pm
Just remember, hubs are for 1992! Thumbs Up
Post #151021 Thu Jan 10 2008 5:27pm
what's a 1992???
Wink RRS TDV6 Gone but still around
Post #151023 Thu Jan 10 2008 5:29pm
Misery
JayMann wrote:
what's a 1992???
There you go VA the geek has answered. Very Happy Very Happy Very Happy Very Happy Very Happy Very Happy Very Happy Very Happy
Post #151029 Thu Jan 10 2008 5:52pm
Only cuz you was born in 1902 RRS TDV6 Gone but still around
Post #151031 Thu Jan 10 2008 5:53pm
Havank
Ok VA
As you still do not have an answer on your question what to do
I have also some outbuildings, we call it the cabin (that is where my boys hang-out)
So i originally had two internet connections, but i have changed that for this one
They are wall plugged range extenders
http://www.netgear.co.uk/wallplugged_adapterkit_hdxb101.php
performance is up to 200mbps so much better then wireless
bassically you are using you'r powerlines as a network cable, at one end you upload the network signal and at the other end you take it off, you can take it into a switch or back into wireless, installation takes about 5 minutes and its more simpler then running cables, as you have to terminate cables Twisted Evil
just have a look Razz
Post #151140 Fri Jan 11 2008 10:54am
Didn't he say he had tried that and it wasn't good enough? Confused
Post #151143 Fri Jan 11 2008 10:55am
Havank - yes I've tried those but for some reason they don't work. Big Cry Big Cry Thanks 2005 Zambezi TDV6 - Gone but not forgotten
Post #151148 Fri Jan 11 2008 11:01am
Havank
OK, must have overlooked that part Embarassed
Other solution is to get a second broadband connection, (which is ofcourse more expensive) Big Cry
your solution is more in the directional antenna like this
http://www.netgear.co.uk/extra/b_wirelessantenna_ant24d18.php
this provide you point to point wireless connection between buildings
Post #151159 Fri Jan 11 2008 11:49am
Second broadband means two routers, means two address ranges, means limited roaming between house and outbuilding without service interruption.... Big Cry
Post #151161 Fri Jan 11 2008 11:56am
The tel line that runs to 'the barn' has adsl on it but the router is in the house and the wireless signal doesn't reach 'The Barn'. Can I attach another router on this line? 2005 Zambezi TDV6 - Gone but not forgotten
Post #151162 Fri Jan 11 2008 12:04pm
Josh
Why don't you just move the shed closer to the house Question Rolling with laughter Rolling with laughter Rolling with laughter TDV6 - gone
TDV8 - gone
Post #151164 Fri Jan 11 2008 12:09pm
It's not a shed! Evil or Very Mad 2005 Zambezi TDV6 - Gone but not forgotten
Post #151166 Fri Jan 11 2008 12:13pm
Page 2 of 4 <1234>
