Home > Maintenance & Modifications > 22x10 alloys... |
PauloAmore Member Since: 27 Jan 2007 Location: Bonnie Scotland Posts: 1289 |
TUV certified. Interesting.
Wed Sep 05 2007 12:50pm |
umbertob Member Since: 23 Sep 2005 Location: Pasadena, CA Posts: 944 |
I assume that a rim company going to the trouble of producing an Overfinch knockoff and getting it TUV certified, would also be savvy enough to make sure it fits over your front Brembos, but the fact the rim is 10" wide really means virtually nothing. It could be 19x9 and fit just fine, or 22x11 and grind against those calipers, or vice versa. Besides the required 5x120 lug pattern, do you know the offset? Some reputable manufacturers make wheels of identical design for the Sport, but with different offsets, clearances and more or less pronounced "lip", depending on whether the alloys will be fitted on Brembo or non-Brembo equipped Sports. If the maker doesn't know for sure, I'd be very careful about purchasing from them without a prior "test fit" on your car. In fact, I'd be very careful about purchasing from them, period.
Thu Sep 06 2007 3:14am |
db Member Since: 28 May 2007 Location: London Posts: 19 |
thanks for the info...and I hear what you are saying.....I'm nervous of spending less on Overfinch 'Style' alloys and they not be right.......
Thu Sep 06 2007 9:01am |
PJPR01 Member Since: 12 Mar 2006 Location: Houston, Texas Posts: 355 |
Overfinch Tigers in the U.S. run about 3900 new, if I'm not mistaken...are you saying they are 4000 Pounds Sterling in the UK??? That's incredible...too many taxes there... PJPR
Fri Sep 07 2007 3:38am |
I think its actually about 3700 pounds sterling with tyres
Mon Sep 10 2007 8:54pm |
cowey101 Member Since: 17 Jul 2007 Location: Gods country! Posts: 403 |
Java Black TDV6 HSE - Java Grandes Marques 1/18 - Ducati 749s |
Mon Sep 10 2007 9:11pm |
