Home > Technical > Voice Dialing |
Tedf Member Since: 31 Dec 2006 Location: Copenhagen Posts: 36 |
I have a Nokia 6230i in the cradle. It works perfectly to dial from the directory, yet if I try to dial with voice commands, it responds " No handset connected".
Tue Aug 07 2007 2:02pm |
Pelyma Member Since: 29 Sep 2005 Location: Sussex Posts: 1497 |
You have stored the numbers in the car rather than the phone? |
Tue Aug 07 2007 4:55pm |
oh yes, painfully I recorded the names and phone numbers. It has worked, but now, I get a written message
Tue Aug 07 2007 6:29pm |
Has the phone got the correct software? 2005 Zambezi TDV6 - Gone but not forgotten
Tue Aug 07 2007 6:44pm |
oh??
Tue Aug 07 2007 6:51pm |
Look here.
Tue Aug 07 2007 7:02pm |
thank you very much...very informative.
Tue Aug 07 2007 9:06pm |
No downgrade should be needed. The problem with this phone sytem on the RRS is simple - it's crap and bits that should work don't. Your not the first to experience problems and you will not be the last. I had similar problems and sorted them out by trial and error and replacing the phone for the most basic phone for the cradle. I have a phone always in the cradle. 2005 Zambezi TDV6 - Gone but not forgotten
Tue Aug 07 2007 9:12pm |
I too have a 6230i always in the cradle.....sometimes it works, somtimes not...just haven't been able to figure out why.
Tue Aug 07 2007 10:21pm |
My 6230i worked faultlessly UNTIL I upgraded the firmware on the phone... I then found I couldn't downgrade it to go back to what I had before. VA is right - generally, the PTI is a bit rubbish, although the MY08 RRSs have a newer Bluetooth module which may make things a bit better.
Wed Aug 08 2007 1:14pm |
ugh...doesn't sound encouraging
Wed Aug 08 2007 4:12pm |
Might be worth asking your dealer if you can get the MY08 bluetooth module swapped into your car? Word has it, it works a lot more seamlessly than the one you currently have
Thu Aug 09 2007 8:50am |
