Home > Maintenance & Modifications > Engine modifications
SteveWilliams
Wales 2006 Range Rover Sport TDV6 HSE Rimini Red
Are there any modifications on the market that you can use to improve Power and MPG that don't invalidate the warranty?
Post #129925 Sun Aug 05 2007 9:35am
Josh
Truthfully.......No.
There are some devices that are plug in that if you remember to Exclamation you could remove prior to LR doing any work on the vehicle.......but I doubt you will find anyone on the forum who thinks they are any good. They push in more fuel without altering some other factors which may lead to further long term problems.
If you're going to do it then reprogram the ecu (chip it). I think we all agree this is safer.
But I'm afraid if there is a problem and LR suspect you have modified it then they are unlikely to uphold the warranty if they can attribute any connection to the modification. TDV6 - gone
TDV8 - gone
Post #129945 Sun Aug 05 2007 12:49pm
Steve,
Just a thought - Speak with your supplying dealer - if they are happy to do a performance upgrade for you then if there is any problem later then they should be able to handle it (i.e. wrt to any warranty problems)
Post #129953 Sun Aug 05 2007 1:51pm
SteveWilliams
Thanks for that guys. I didn't think there would be. Will see what the dealer says next time i'm home.
Post #129965 Sun Aug 05 2007 4:43pm
