![]() | Home > Maintenance & Modifications > What’s life like with a set of Stormers ?? |
| Rupert Member Since: 13 Mar 2006 Location: Here !!! Posts: 1194
Back again, with another question………..
| shmoogle Member Since: 07 Sep 2005 Location: ... and for every sprinkle I find, I shall kill you! Posts: 24350
I've got an idea the 295/45 profile is actually the standard alternative to the usual 275s... so, should be plenty of happy users out there. |
Ah !
Just to re-visit this thread once more, as I’ll soon be shoeing “Rupert” with his new rims.
| umbertob Member Since: 22 Sep 2005 Location: Pasadena, CA Posts: 944
Your speedo will be about 6.3% too slow compared to the stock 275/40/20s, your mpg average will suck - but only on paper - and your odometer will equally record about 6.3 miles less for each 100 you actually drive, not necessarily a bad thing when resale time comes around. |
You have 295/40s, E? Not 45s? |
I was hoping to get the 295 40’s like ENVOY but in the end the 45’s came in “way” cheaper, so that combined with seeing that many on here recommended the 45’s over the 40’s that’s what I went for.
| rrsjo Member Since: 28 Nov 2006 Location: North Cambs Posts: 551
Have you not thought of having the speedo recalibrated. I know on Jaguars this is easily done at the dealers by just plugging in and specifing the tyre size - I would have thought the same would apply to the RRS. After all, the factory must do the same when the different wheel sizes are fitted when the vehicle is built. |
You know, I’ll look into that rrsjo |
Had the Stormers fitted to “Rupert” tonight & they look amazing.
| ENVOY Member Since: 09 Nov 2006 Location: In the shit as usual Posts: 5823
I have had no issues with rubbing of my 295's |
Any idea how close they are to any components of the front suspension up at the top ??
| drevs Member Since: 04 Sep 2006 Location: USA Posts: 43
OT, but related... I had a set of offorad tires fitted to my RRS and they were damn close to rubbing on the upper spindle, right at the knuckle. I decided to pass, since the clearance was SO close. If you guys have ok luck with an extremely tight tolerance there, I may have to reconsider. Keep us posted. |
Rupert i will double check this morning on the tyre size and i will look again at the clearance |
| All times are GMT |
