Home > General (L494) > L494 Panoramic Roof Seal
Renesis
Hello All
I’m really struggling to find the part numbers for the sliding pan roof seals. I need 2 seals which run the length of the roof and one seal which goes around the fixed part which I believe is LR084562.
Does anybody know which seals are required for the roof length. Picture attached.
Been to main dealer which weren’t too helpful due to the cyber attack.
I know about the leaking roofs but every morning I’ve got 2 puddles at the rear of the car due to the shot seals.
2018 PHEV
Thanks
Post #649952 Sat Sep 27 2025 10:07am
2 RRS
United Kingdom 2013 Range Rover Sport SDV6 Autobiography Bourneville
You can't get those seals separately, they come with the trims that they are attached to. The seal is available that goes around the fixed glass roof on its own, the seal for the sliding glass and half moon glass come with the glass unfortunately.
Quite often some of those trims on ebay, L494 and L405 swb are the same I seem to recall.
Post #649957 Sat Sep 27 2025 3:37pm
Renesis
I decided to take the trim off and came to the same conclusion. Going to try removing it and putting a replacement rubber strip onto the trim.
Post #649959 Sat Sep 27 2025 5:16pm
2 RRS
Here's the catalogue with part numbers if you have no joy
https://parts.jaguarlandroverclassic.com/p...and-rover/
Post #649960 Sat Sep 27 2025 5:46pm
