Home > Technical > AFS Headlight
Big Boy R44ROV
AFS Headlight
Hi all.
Bit of a while since I last posted, but have a question.
Headlight on my 2014 5.0SC AB decided to play silly Censored and went intermittent then failed completely. Turns out it was the dreaded wheel arch earthing connection on the nearside which snapped (as they do). This was fixed and the headlight is fine and working as it should.
Trouble is, the DRLs dont work and the nearside front indicator is intermittent and faint. You can hear the relay kicking in normally, then missing and going fast, then back to normal. When the alarm is clicked the indicator doesn't flash on the nearside. Back light cluster works fine. Hazards work fine.
The headlight is is an AFS DK62-13W030-GG.
1. Can another AFS headlight be swopped for this?
2. Can the DRLs / indicator be fixed? is it on the same ballast control unit
3. Will it need coding to the vehicle, and if so, can an IID do this?
Hope someone can give me a clue on this. Question Question
Post #649680 Sat Sep 06 2025 11:04am
