Home > General > Rear Cross Member
Chris123
Rear Cross Member
2009 (facelift) Range rover Sport.
I've noticed that the rear cross member is showing signs of corrosion, and will need some welding.
Is it possible to replace the entire cross member, if so who supplies the item or is it a case of repairing what's already there
Post #649037 Wed Jul 23 2025 8:30pm
If you are referring to the rear most x member with the tow hitch socket in it, you can buy this separate google KVB500101 it should come up, does show LR direct as having stock should be others as well.
Post #649038 Wed Jul 23 2025 9:02pm
Chris123
Thanks Col
Post #649039 Wed Jul 23 2025 9:05pm
