Home > Maintenance & Modifications > Head light replacement?
andrew kennedy
France 2006 Range Rover Sport TDV6 HSE Maya Gold
2006 Sport. The plastic on the headlights is very discoloured. I have purchased a kit to try an clean them up....which is proving a long and difficult job......then I wondered....is is possible to simple replace the front plastic pieces? I appreciate the whole headlight can be replaced but at a cost. Andrew Kennedy
Post #648799 Sun Jul 13 2025 3:12pm
yes.
https://www.ebay.co.uk/itm/176317438721?_s...BMmIz6woBm
or AliExpress
Post #648800 Sun Jul 13 2025 3:28pm
andrew kennedy
That's good new Andy. just how easy/difficult would you say they are to replace, baring in mind I only have the basic of tools. Andrew Kennedy
Post #648801 Sun Jul 13 2025 4:08pm
Well you need an oven big enough to put the headlight in, to melt the glue
Some gloves
Then prise off with flat blade screwdrivers
Post #648802 Sun Jul 13 2025 4:12pm
andrew kennedy
As always thanks for the advice Andy Smile but think I will have to either clean mine off or try to sort out a new pair online. Andrew Kennedy
Post #648804 Sun Jul 13 2025 6:50pm
Usually you can use various grades of wet and dry sandpaper
And water to clean them up.
Then Bit of a polish. Like me meguirs scratch X
Post #648805 Sun Jul 13 2025 6:57pm
Must be a 1000 videos of
?si=rcchcn81NkOCb-Mb
?si=hYjRAcxC4oSu3ruo
Post #648806 Sun Jul 13 2025 7:01pm
