![]() | Home > General (L494) > L494 2015 - P0234-77 Turbo Overboost/Full DPF |
41jules1967 Member Since: 01 Jun 2025 Location: Leeds Posts: 142 ![]() ![]() |
So first problem - are the readings correct?
WRHICKS Member Since: 30 Jun 2025 Location: Ipswich Posts: 2 ![]() ![]() |
So, I am potentially thinking about this the wrong-way-around. I was thinking the overboost error (currently unknown) was stopping the regen and subsequently causing the DPF to become full. But it could be, in theory, an issue with the DPF/soot levels causing the MAP sensor to be blocked, and giving me the overboost error instead?
So i"m hesitant to respond as I'm only a hobby mechanic and most of my knowledge is based on the experiences of others as my own SDV6 was pretty much trouble free up until the time (I suspect) the inlet manifolds split and I took the decision to trade it in rather than repair it - hence why I now have an RRS
