![]() | Home > General (L494) > Front wheel arch liner clips |
2 RRS Member Since: 04 Sep 2016 Location: Shropshire Posts: 225 ![]() ![]() ![]() |
The two holes opposite each other are for TPMS sensor receivers, not that they ever fitted that model of sensor to the 494, but you are correct there is nothing behind them, trim just tucks into the wing/bumper edge at that position plus 2 screws and 3 push clips in total for the under liner, at the lower front edge there are 2 screws that go up through the brake air diffuser. |
shatnersbassoon Member Since: 23 May 2025 Location: Wiltshire Posts: 9 ![]() ![]() |
Thanks for the info.
