Home > General (L494) > MY17 DIY Ride height calibration
shatnersbassoon
Hi all,
I have a 2016, but MY2017, so the newer infortainment, if that makes a difference.
My suspension doesn't quite sit correctly I don't think. A bit high at the front and one of the rears is maybe a little lower than the other.
Are there any decent OBD style tools that would allow me to calibrate the suspension myself? Something that won't break the bank of course. I've seen some videos showing "iLand" being used, but that looked to be the previous model sport.
Matt
Post #648383 Mon Jun 16 2025 7:46pm
The system has a bit of "variation" built in. SO trying to get it to sit perfectly square when on the driveway can be a fool's errand. When moving, the system generally sits correctly.
Unless you're getting uneven tyre wear (and that is more likely an alignment issue), I wouldn't worry too much. 2012 SDV6 - it's missing a couple of cylinders
Post #648416 Tue Jun 17 2025 9:55pm
