![]() | Home > Faults & Fixes > Air suspension fault. All bags deflate. |
Disco_Mikey Member Since: 08 Apr 2012 Location: Dundee, Scotland Posts: 4526 ![]() ![]() ![]() |
Fault codes? |
gibbo Member Since: 23 Nov 2020 Location: Bristol Posts: 8 ![]() ![]() ![]() |
When the bags are inflated I have no fault codes. All sensors are getting 5 volts.
RRSTDV8 Member Since: 13 Aug 2011 Location: Northamptonshire Posts: 9138 ![]() ![]() ![]() |
One issue that can cause that is a calibration corruption issue - if the system thinks it's cross axled when it obviously shouldn't be, i.e. at normal road speeds, it drops to the stops (bags deflate). Also, if it loses more than one height sensor, it drops to the stops.
And I'm surprised to hear that you've had suspension air bags burst. What caused that? Pretty rare as I understand it. 2012 SDV6 - it's missing a couple of cylinders
If the red warning light came on, you have a fault code logged
