Home > General (L494) > Pre-emptive sunroof drain maintenance
Woppyman
United Kingdom 2012 Range Rover Sport Supercharged Autobiography Siberian Silver
Hi all, I was doing some research and came across lots of info about how to repair a rusted sunroof drain spigot, but nothing about prevention.
I took my rails off and poured water down. The pipes were rusty but I pulled the headlining down a bit and no water leaking out and coming through headlining.
So to ‘stop the rot’ I have done following.
1) Using a bolt, GENTLY rub in and out of hole. The thread acts as a file to remove loose rust flakes.
2) With a small paint brush used Hammerite rust converter (careful not to spill on paintwork).
3) Leave for an hour and reapply.
4) after 24 hours paint with black touch up. 4 hours later second coat. Push brush right down hole.
5) after 12 hours finish with lacquer. Second coat after 4 hours. Push down hole again
6) after 12 hours pour warm water down to make sure water flows.
Hope this helps someone.
Time will tell if it works.
 Evoque HSE Dynamic
5.0 Charger MY12
Post #647633 Wed Apr 09 2025 8:22pm
