![]() | Home > Technical > Suspension fault |
Heheshamon Member Since: 31 May 2023 Location: Leicester Posts: 36 ![]() ![]() |
Ok so just been out and the whole suspension is starting to sag, the front is the same height but the rears are getting to the same point now and alot lower than normal on the onboard display, it's also flashing raising/normal and on the dash it's saying suspension fault then normal height only so I think the height sensors are calling for air but then the system is saying there's a fault.
Disco_Mikey Member Since: 08 Apr 2012 Location: Dundee, Scotland Posts: 4526 ![]() ![]() ![]() |
Probably find the compressor has failed... |
Hmm you've got me worried now think I'll be ordering a compressor just incase and return if not required, the compressordoes run until the ecu throws the fault, don't want to be emptying the rest of the air out and be stuck on the bump stops. |
Just had a look at the compressor and centre valve block all seem OK compressor runs until the fault occurs, although there is some white powder around the dryer seal and a couple of the voss connectors on the valve.
That is exactly what will happen due to low output from the compressor
Yeah your probably right I've got a new AMK on its way we'll see what happens, i think its just wishful thinking that it will be the valve and won't have to cough up the dough these things cost a fortune to run hate to think how much a garage would have charged for everything I've done. |
Ok all good changed front valve block and compressor the one that was in must be original as said I reconditioned it 6 months ago but it certainly looks past it.
RRSTDV8 Member Since: 13 Aug 2011 Location: Northamptonshire Posts: 9138 ![]() ![]() ![]() |
That compressor has a built date of 21-02-2013 it seems so it's done pretty well! 2012 SDV6 - it's missing a couple of cylinders
