Home > Technical > Suspension Fault
MarkSTurner
United Kingdom 2012 Range Rover Sport 3.0 TDV6 HSE Santorini Black
Suspension Fault
Hi I have 2016 RRS Autobiography and whenever I start the car for the first time on a day after approx 20 to 30 seconds from selecting drive and driving off I get an amber suspension fault appear; on switching off, locking car and then restarting clears the fault with no reoccurrence for the rest of the day. The car drives perfectly in all other respects. I’m therefore suspecting a low voltage / canbus error rather than a physical issue with the suspension.
Has anyone else experienced this issues or have any suggestions/ views? My next move will be to plug in my Topdon to see if any codes are stored ( but not active).
Only had the car a month so still getting know it’s querks.
Thanks in advance
Post #647329 Tue Mar 18 2025 12:06pm
Big Boy R44ROV
Worth checking the batteries and alternator. I had spurious messages flag up and it was alternator failure and main battery. Also check the compressor breather filters. Cheal easy fix.
Post #647330 Tue Mar 18 2025 8:29pm
