Home > General (L494) > Dynamic Response Fluid
Karlp606
Hi guys,
Just been giving the L494 a check over and a hoover out after a airport run.
I know there's no power steering fluid on the L494 but the dynamic response fluid looks very low or empty I cant see any fluid looking through the top of the reservoir, would an error pop on screen when its low etc? I don't want to over fill it and if it does need filling what do people use?
Thanks
Karl Thumbs Up
Post #647120 Thu Feb 27 2025 4:10pm
Karlp606
Edit -
Just seen this at halfords would this be okay?
https://www.halfords.com/motoring/engine-o...lsrc=aw.ds
Compatibility:
Suitable for use where the following applications are called for: CHF 11S and CHF 202
Post #647122 Thu Feb 27 2025 4:33pm
DWA
Hi, you should get a warning on the dash, don't remember exactly what it says now but if you get it you will absolutely know about it, when it's as low as you say it cant be far away from coming on, mine was leaking at NSF wheel, and very quick to pump out the fluid, pumped out 1l of fluid in 4 miles when it went to be diagnosed, I used this stuff as it was half the price of JLR fluid worked perfect and can be found on an online marketplace.
https://www.westwayoils.co.uk/products/lan...9916721318
Post #647123 Thu Feb 27 2025 5:41pm
Karlp606
Cheers ordered and arrived saturday! Topped up and all good Smile
Post #647142 Mon Mar 03 2025 11:57am
DWA
No problem, pleased you got it sorted out
Post #647181 Wed Mar 05 2025 8:54pm
