Home > General (L494) > 3.0 SDV6 Inlet manifold oil leaks
RRS?
What’s the general consensus when it comes to rectifying oil leaks from the inlet manifold.
Has anyone had success by just replacing the seal?
I’ve read genuine is realistically the only route to take if replacing the manifolds?
Are the manifolds prone to warping? 2004 D3 HSE TDV6
2011 D4 HSE SDV6
2015 L494 RRS Autobiography SDV6
Post #646567 Tue Jan 28 2025 11:59am
Disco_Mikey
The manifolds are prone to cracking and causing boost leaks
If it's leaking oil, I'd put another genuine manifold on it. Not the kind of job you want to be doing twice Thumbs Up
Post #646571 Tue Jan 28 2025 5:04pm
RRS?
Cheers Mikey, was hoping someone like yourself would pop along. 2004 D3 HSE TDV6
2011 D4 HSE SDV6
Post #646574 Tue Jan 28 2025 5:37pm
