RallyeSport
Auxilary belts, tensioners and pulleys | |
Hello,
I have a 2010 3.6 TDV8 and have a noisy pulley on the auxiliary belt system, the car has done nearly 95,000 miles.
I know I have 2 auxiliary belts, 2 tensioners and 2 pulleys on the 3.6 TDV8.
Do I need to remove the viscous fan assembly (whereby I'll need the 2 spanners)?
I downloaded the TDV8 topix pages for the correct orientation of the belts and tensioners/pulleys.
Is there a definitive guide for doing the job please?
I'd hope its a loosen belt tension, remove belts, remove tensioners x2 and pulleys x2 and refit/retorque and then refit the 2 belts, I'd seen the viscous fan can be a bitch to remove.
Well, I know Matt Armstrong removing one from a project SVR had serious problems, leading to needing a new engine, due to the viscous fan bracket snapping and pulling a lump out the block, please don't tell me it'll be a similar job possibly????
Cheers in advance
Dean
Mon Jan 27 2025 10:50pm |
