![]() | Home > General (L494) > horrible tapping noise, Running rough |
Nick900 Member Since: 11 Mar 2022 Location: Kent Posts: 89 ![]() ![]() |
Hi Rob,
Disco_Mikey Member Since: 08 Apr 2012 Location: Dundee, Scotland Posts: 4531 ![]() ![]() ![]() |
Is this related to the injector seal issue you've just had? |
Rob Evans Member Since: 03 Sep 2024 Location: Kenilworth Posts: 17 ![]() ![]() ![]() |
Hi Nick, thank you so much for taking the time to reply. It’s really appreciated. I will try all of the above . I have seen the actuation test but didn’t know what it was for . I will reply later and once again thank you |
Hi , I don't think there is a connection with the seal issue but who knows!!! lol
We have good news 🙏…I took all the engine covers off etc and disconnected all the wires to the injectors …carefully measured the resistance across the 3 injectors on the near side bank . I injector showed a much higher resistance across the coil and interestingly, occasionally to ground also .Luckily I had a spare ( secondhand ) injector which I fitted and all is ok now!!!! Thanks for your help guys and hope this helps someone else at some point🙏 |
