![]() | Home > Maintenance & Modifications > Rim size |
Col Member Since: 02 Sep 2012 Location: Hawkes Bay NZ Posts: 5109 ![]() ![]() ![]() |
The Rim PCD on the L320 and L494 is the same 5 x 120 so they will fit on the the hubs and over the 6 pots O.K. however they do have different offsets, I think it's 53mm for L320 and the L494 depending on the style/size of rim varies between 45 and 49mm so you may need to check clearance. I'm sure it's been done and somebody will be able to confirm yes or no.
