![]() | Home > General > Battery voltage question |
| Andy K Member Since: 18 Sep 2015 Location: GL Posts: 5138
I had a Jag that had the pitted contacts on the starter relay. So I would suspect that was your issue. |
| Jabba Member Since: 25 Jan 2023 Location: Norfolk Posts: 231
Thanks Andy
| jimbg Member Since: 29 Jan 2013 Location: No longer by the River Dart.... Posts: 1924
Measure it across the terminals
Thanks Jim
Right, multimeter sorted.
| RRSTDV8 Member Since: 12 Aug 2011 Location: Northamptonshire Posts: 9155
Battery needs charging with a decent smart charger. Although I reckon it's looking a bit tired. A drop from 12.2V (not great) to 11.3V (rubbish) suggests either it needs a decent smart charge or it's Charge it and see what happens. Edit: I see stuff changed. Typical. 2012 SDV6 - it's missing a couple of cylinders 2008 TDV8 - it was a labour of love and is much missed |
Thanks for your reply RRSTDV8, yes, both the battery and alternator were replaced with LR genuine items just over 4 years ago/27000 miles ago.
Well, just popped out in the rrs, pressed start and then 'click', the second press it started fine.
| All times are GMT |
