Home > General > ACE pipes for RRS 2006 out of stock worldwide?
hvbil
Norway
Hi, it seems the world is out of stock for ACE pipes to RR Sport 2006, part RQA500018. Dealers report that LR is out, and has no ETA / estimated time for delivery. From forums it seems this has been a repetitive issue for years.
My front pipes from valve block to anti roll bar is leaking, and car then not functioning. It seems a bit strange that a set of standard pipes, just bent in a specific way is hard to find.
It seems that there are different part numbers that could be interchangeable, but I can not find anything conclusive on this. Does anyone know if there are part numbers interchangeable with RQA500018, for example LR019908? Different sites say these are for year 2005-2009, others have a split for 2005-2007, and then 2008-2009.
Any tips on where to find the pipe repair set would be greatly appreciated.
Post #644568 Sun Oct 06 2024 11:11am
Billy82
How about ebay
https://www.ebay.co.uk/itm/225173870467
Post #644574 Sun Oct 06 2024 3:55pm
gogsy1956
That link is not for ACE pipes 2010 RRS, TDV8
bali Blue / colour coded
side steps / flappy paddles
black perforated leather
22" overfinch
Post #644576 Sun Oct 06 2024 4:55pm
Billy82
Sorry it just xame up when I searched
How about
https://www.johncraddockltd.co.uk/rqa50001...block.html
In stock
Post #644577 Sun Oct 06 2024 4:58pm
hvbil
Norway
Thank you for tip, but have already checked and got reply by mail that it is not available from any of their supplere.
Post #644589 Mon Oct 07 2024 12:24pm
SuperC
United Kingdom 2012 Range Rover Sport Supercharged Zermatt Silver
I’ve had all sorts of fun with my front ACE pipes. Take a look here and find the part you’re looking for. I wish you luck but I’m sure you’ll find the solution.
https://parts.jaguarlandroverclassic.com/p...5NjU2OTU./
There are a few posts on here on this subject. The full kit is not available but, check the part number LR019385. If this is the part, you can still get it.
Also, these topics might help. https://www.rrsport.co.uk/forum/topic61326.html and https://www.rrsport.co.uk/forum/topic55087.html Cheers,
Stuart.
RRS 2012 HSE 5.0 S/C Zermatt Silver.
RRS 2005 4.2 S/C First Edition Rimini Red- Gone but not forgotten
Defender 2005 TD5 XS Black - Gone
Freelander 2006 HSE Blue - Gone
Post #644921 Sun Oct 27 2024 8:48am
karlos01
following this thread is it the same situation for the rear ace pipes as I've got a leak on the rear ones
Post #644924 Sun Oct 27 2024 6:21pm
DorsetJag
There are some available on Ebay from Lithuania, and I just got mine from lrclassicparts delivered in 2 days.
Post #645143 Fri Nov 08 2024 3:54pm
SuperC
Rears are available direct from JLR. https://parts.jaguarlandroverclassic.com/p...and-rover/
May also be available from other suppliers.
There are 2 separate part numbers:
RQB500313
RQB500334
Best of luck! Cheers,
Stuart.
Post #645185 Mon Nov 11 2024 12:10pm
hvbil
Norway
SOLVED + TIP for changing fromt ACE pipes
PROBLEM SOLVED.
Finally the pipes were back in stock here, the kit was not available, but the individual pipes and parts could be selected from an informative page:
https://parts.jaguarlandroverclassic.com/p...yMTAzODIy/
This is a really good site, and quick delivery, also intl, as soon as parts are in stock.
TIP for changing the front ACE pipes, at least on an L320, 2006, 4,2 sc: You do not have to separate chassis from the frame to get the new pipes in. The pipes are stuck between the chassis and the frame behind a bolt, which has lead many to separate chassis and frame to be able to get the pipes in place. Instead, you may cut off the "lip" attached to the frame, through which the bolt that secures it to the chassis sits. Release the bolt, cut off this steel "lip", then the new pipes can be entered up from below and fitted. Afterwards, you weld on the "lip", and secure the bolt. Of course, you need to know what you are doing when you are welding. Saves a day's work by not having to separating chassis and frame Smile
Post #645540 Fri Nov 29 2024 10:35pm
