Home > Technical > 2011-2013 facelifted L320 — power tailgate inertia switch
bamber2000
United Kingdom 2011 Range Rover Sport SDV6 SE Galway Green
I have a RR Sport L320 built in June 2011. It’s the ‘facelifted’ later L320 with the single piece tailgate.
While doing some other work, I had to remove the interior trim of the tailgate. I was surprised to see that it has the electric tailgate control unit, and other, related parts. The wiring loom is complete with all of the connectors necessary for the electric tailgate. The only parts absent are the two electric struts, the manual switch to initiate closing, and the ‘override inertia switch’. (See the attached photo from the workshop manual.)
So my plan is to buy the struts, and the two switches and then, if necessary, pay my local specialist to reprogram as necessary. BUT … I can find no reference to the ‘override inertia switch’ anywhere online. I’ve no idea what it looks like and know no part number. All I know is what I can get from the workshop manual: it plugs into a green connector numbered C3737. That’s not much to go on!
Can anybody help me source an override inertia switch?
Does anybody know a part number?
Can anybody tell me whether it’s necessary for the electric tailgate to operate?
Peter RR Sport SE SDV6 (first registered July 2011)
+Keyless +Timed climate +5 cameras +Sunroof +Adaptive cruise +Rear passenger video +Remote pre-heat
+Alpine subwoofer and amplifier +Extra (LED strip) load space light
[Discovery 300TDi gone (for parts) but not forgotten]
Post #642553 Mon Jun 10 2024 11:12pm
If the powered struts and closing switch are missing, how do you lift and close the tailgate?
Switch, item no.4 has a green connector from the harness.
Post #642554 Mon Jun 10 2024 11:19pm
bamber2000
Thanks, Col, for replying.
– Unlatch — concealed switch/handle above the number plate/dash button/key fob button
– Lift with assistance from the original, unpowered struts.
– Close by pulling down on the tailgate handle.
– Latch is automatic, powered by the latch motor.
I think you’re saying that the manual close switch IS the ‘inertia override switch’. Yes?
Post #642556 Tue Jun 11 2024 8:17am
That switch on mine (LR025424) certainly has a green connector from the harness, can you see the connector through the cut out for the switch on the lower edge of the tailgate trim? That's the only switch that seems to be listed in the tailgate it's self, interesting as they do list manual struts for later cars Vin No. CA000001 on which I thought was about when they started fitting the one piece tailgate, maybe it was a option on later vehicle to have either manual or auto strut's on it, looks like the strut top mounting bracket may be different as well, have you got a picture of the strut mountings on your vehicle by any chance?
Post #642557 Tue Jun 11 2024 8:51am
I wouldn't bother messing around with it. In my experience, half of the time the hatch unlatches but doesn't lift, or it'll lift a bit then stop, and a minority of the time will it work properly. And there's no remote close on it (although someone did lash up a way of doing that, I think), so you still need to press the button on the hatch to close it.
It just feels like an option put in to make it feel more "luxurious" but, being JLR, it's a half-arsed job. 2012 SDV6 - it's missing a couple of cylinders
Post #642560 Tue Jun 11 2024 9:55am
I can't speak for anyone else, but In my experience the tailgate on mine has failed to open twice in 11 years of ownership and a new switch sorted that, the "lash up" remote has worked perfectly since it was fitted in March 2016 over 8 years ago which is actually longer than some factory fitted component have lasted like some TDV6 engines for example.
Post #642561 Tue Jun 11 2024 11:12am
Mine will unlatch and fail to open either on the key and on the button at various times (opens on the dash button every time, however). Pain in the butt. I'd rather have the old manual tailgate with the opening glass section from my old TDV8, thanks. A more useful thing but, I guess, not luxurious enough. LR have reduced the practicality with every increase in luxury over the years, IMO. 2012 SDV6 - it's missing a couple of cylinders
Post #642563 Tue Jun 11 2024 3:41pm
bamber2000
Thanks for your interest, Col.
I have the tailgate trim panel off at the moment. Indeed, there's a green connector in the right place to mate with a tailgate close switch. I've been confused by the fact that that close switch on the end of the tailgate is described in the service manual as the 'override inertia switch'.
Attached are photos of the upper and lower hydraulic strut fixings. RR Sport SE SDV6 (first registered July 2011)
Post #642582 Wed Jun 12 2024 2:25pm
Couple of picture of the strut mountings on mine, lower mounting looks very similar, top one looks as so it may be slightly different shape although the strut is obscuring it slightly.
Post #642600 Wed Jun 12 2024 10:25pm
bamber2000
The difference between the top fixings on yours and mine appears to be in the way that they attach to the tailgate. Now I’m wondering why. RR Sport SE SDV6 (first registered July 2011)
Post #642604 Thu Jun 13 2024 4:55am
If the picture is correct this is the top R/H mounting bracket listed for the powered strut , the L/H one is LR030939, not sure how it compares to the shape of the R/H bracket on your vehicle? Part No. LR030894 R/H & LR030805 L/H appear to be the ones listed for the one piece tailgate with standard gas struts.
Post #642605 Thu Jun 13 2024 6:50am
bamber2000
I think we’ve been using ‘top’ and ‘bottom’ in opposite ways to each other! You seem to be referring to them in position with the tailgate closed, so I’ll change to your designation.
That being the case, thanks, it’s useful to know that the top mounting plates are available (in case I have trouble as a consequence of corrosion fitting new electric struts to the old balls).
Do you have an opinion about genuine LR v. aftermarket struts? Have you had to change yours and if so what did you buy? RR Sport SE SDV6 (first registered July 2011)
Post #642607 Thu Jun 13 2024 8:03am
I'm currently at the bottom of the world so the could explain the confusion in position. Rolling with laughter I can't really say a preference on genuine or aftermarket replacement struts as I have never had a issue with mine, personally I would probably go for genuine rather than cheap crap of the likes of fleabay unless I could find the o.e. manufacturer, but never having to replace them have had no need to get a comparison in quality and price between suppliers.
I did wonder if there is a slight difference in the top bracket's due to the larger diameter of the power struts to give more clearance from the bodywork.
Post #642611 Thu Jun 13 2024 8:30am
