Home > General > Help please PCM P006A
HMCH
United Kingdom 2012 Range Rover Sport 3.0 TDV6 HSE Santorini Black
After some advise on this code
My car has been going in and out of restricted performance ove the past few days it seems to be worse in the morning?
Any advise much appreciated
I've recently purchased the SDD diagnostic and found this code
Post #641362 Sun Apr 21 2024 9:49pm
Karlp606
Sounds like you've got the dreaded manifold break, take it to a garage to get smoke tested they'll be able to diagnose.
Post #641383 Mon Apr 22 2024 3:13pm
HMCH
Yeah I think you could be right : (
I'll get a smoke test booked in
I've just watched a video on YouTube and the guy takes the body off the chassis to do the job Surprised
That's going to be expensive
Post #641394 Mon Apr 22 2024 9:36pm
Cpt Jack Sparrow
Wales 2013 Range Rover Sport SDV6 HSE Fuji White
Hi
Watch this one from LR Time
&t=745s
Had your exact symptoms and code on My TDV6 RRS, did this exact fix with his recommended changes and all fixed no code, no restricted performance. and all for £7.99.
Is it a permanent fix? no idea.... but it has lasted well, and if it returns I'll go in for the big job..
Paul
Post #641415 Tue Apr 23 2024 6:23pm
HMCH
Hi Paul
Good stuff fella I'm definitely going too have a go at this
Cheers pal 👍
Post #641432 Wed Apr 24 2024 12:43am
Karlp606
Wow just seen the video!
So is he basiscally blocking the leak with the thin metal shim? How does it stay air tight tho?
Mines booked in with a indy tommorrow to replace the manifold! Now Im in 2 minds!
Post #641444 Wed Apr 24 2024 10:39am
Cpt Jack Sparrow
he bonds the metal plate over the crack on the manifold. Christian uses epoxy to do this however it's only rated to 100 degrees.
I used JB weld which is rated to 287degrees C and 5020psi, pressing the metal plate onto the manifold when shaped correctly forces the weld into the crack. I left it for 24 hours before starting to ensure it had completely cured in place.
https://www.amazon.co.uk/dp/B0006O1ICE?psc...ct_details
Thumbs Up Thumbs Up
Post #641468 Wed Apr 24 2024 11:07pm
Karlp606
Indy just called my drivers side completely blown! So wont be able to do this repair so new manifold going in today.
Post #641477 Thu Apr 25 2024 10:38am
Cpt Jack Sparrow
ah that's a shame, still was worth a try Thumbs Up
Post #641504 Thu Apr 25 2024 8:19pm
HMCH
Karlp606
Has he given you an idea on the price ?
Is it recommended to do both sides at the same time ?
Post #641592 Mon Apr 29 2024 10:03am
Karlp606
Hi all,
Yes got both sides done as your only paying for a few more hours labour rather than having to take all the fuel lines out again etc and the new washers/seals again .
£1200 for both manifolds all in 👍🏻
Post #641594 Mon Apr 29 2024 12:07pm
HMCH
Update on mine I've finally got the time to have a look at mycar over the weekend.
As well as.going into restricted performance mode I now have an engine management light coming on.
I've taken the map sensor out and cleaned it (black oil over the sensor)
Engine management light gone out ....for now!
I purchased a smoke machine to see if I could do the (jb weld repair)
Unfortunately it looks like my leak is from a rubber seal/gasket
I've added a few pictures to show
Post #642243 Tue May 28 2024 9:16am
Karlp606
If you've got oil on the sensor be more than likely a manifold leak as the oil is escaping.
Do the old smoke test and see if you can see anything.
Post #642246 Tue May 28 2024 11:01am
