![]() | Home > Maintenance & Modifications > Belt change service |
Benidorm Mick Member Since: 27 May 2010 Location: Wiltshire Posts: 102 ![]() ![]() |
PS. 2018 |
Disco_Mikey Member Since: 08 Apr 2012 Location: Dundee, Scotland Posts: 4526 ![]() ![]() ![]() |
Presumably they are talking about the aux belt. Charge cooler needs removing, and the coolant system is a f'king nightmare to bleed properly |
Hodson91 Member Since: 09 Jan 2024 Location: Washington, Tyne and Wear Posts: 26 ![]() ![]() ![]() |
Yes correct on both parts, every 4 years aux belts are due to be replaced due the tensioner set up and correct about the intercooler being in the way as thats where the majority of costs are on the labour for remove and refit of that. Cooling system isn't actually too bad as long as you use a vacuum bleeder 2010 RRS, TDV6
