![]() | Home > General (L494) > Vibration at motorway cruising speeds |
b1ecc Member Since: 19 Dec 2023 Location: North West Posts: 22 ![]() ![]() ![]() |
I think I have a similar issue, but it's hard to nail down.
cormacr Member Since: 10 Jan 2017 Location: Wicklow Posts: 33 ![]() ![]() ![]() |
I got new tyres fitted to my 2019 P400e at around 35,000km’s and had a lot of vibration after I refitted the wheels. I assumed it was a balancing issue so I had the wheels redone at a specialist place with Hunter road force balancing. That didn’t make any difference, there was still an issue - the guy did say there was a “hop” in the front right wheel and to move it to the back if there was still a problem. I did that and it’s now perfectly smooth. I am guessing that I swapped front and back wheels when the new tyres were fitted, I took the wheels off and brought them to the tyre centre in a trailer. Current: RRS P400e PHEV HSE Dynamic MY19.5 Santorini
NoExpert Member Since: 28 Jan 2022 Location: Poznań, Poland Posts: 508 ![]() ![]() ![]() |
Sounds like the beginning of a bushing failure. 2011 RRS HSE Luxury 3.0 TDV6 Fuji White on Ebony/Ivory
TheWojtek Member Since: 08 May 2015 Location: Poznań, Poland Posts: 748 ![]() ![]() ![]() |
Exactly, had this on both my RRS - the vibration seemed to come from the rear part of the vehicle, however after replacing the rear control arms it turned out it was the front lower rear bushing that caused it. Regards etc.,
jovenden Member Since: 25 Oct 2021 Location: Hampshire Posts: 16 ![]() ![]() |
Can you point me to more info on this failure ? -- 2019 RRS 4.4 SDVB Autobiography in Carpathian Grey with Silver Wheels |
Check the control arm bushings, front and rear. My initial guess is a front lower arm will have excessive movement. 2011 RRS HSE Luxury 3.0 TDV6 Fuji White on Ebony/Ivory
Would this really be likely to be worn on such a young (low mileage) car (24k miles/2019 model)?
You don't road test it, lift the car and check for play in the bushings with a prying bar. Regards etc.,
In my experience my expectation would be that they’d first road test it to see for themselves what they’re trying to fix (rather than relying on the customer’s diagnosis) - if I was a dealer that’s what i would do too.
Even with the best dealer and evidence you could be in that situation, just how it is these days.
