![]() | Home > General > Stop / Start issue goes on. Grrrr! |
| Lindab Member Since: 20 Nov 2017 Location: Dundee Posts: 934
Battery does not have to be registered. Get a Ctek MXS5 battery conditioner & leave it on until the first green light comes on.
| RRS Dave Member Since: 11 Oct 2021 Location: Suffolk Posts: 35
Hi. Thanks for your reply. Yes, I am aware that the car decides if it has enough juice for the stop/start to work. But I had driven from Daventry (Northamptonshire UK) About 100 miles, Back home to Suffolk in the daylight. No rain, minimal heat, and the blower was on low. And it self-stopped/started just once, as I stopped to reverse onto my drive at home. I know lots of you don't like or use this feature. But I do. But even when I turn it off, after a while I look down, Why would that be?
| Johnrrs Member Since: 16 Feb 2021 Location: Yorkshire Posts: 484
Put the car on a battery charger for 1 night and I’m pretty sure the stop start will work. It always makes mine work. I use a CTEK MX5. It has green lights on it to show you the state of charge of your battery. I read somewhere ages ago that the RRS needs a 4 hour drive to fully charge the battery. Don’t know how true that is though…… |
Thanks very much. I will do that. Thanks David |
Hi Johnrrs. Ta for your sugestion. I did what you said. But before connecting my charger. I thought I would check what the Stop/Start battery voltage was. The engine was not running. Nor had it been running since the previous night. So it was cold. I don't know if I should have been pleasantly surprised. But it read 16 volts. Good or bad?
| Pistnbroke Member Since: 22 Sep 2020 Location: rugby Posts: 477
16v is far too high ///it will gas and bubble from 14.5 V upwards . You have an alternator issue.
Where are you checking the voltage of the battery? |
Check the main battery with engine running at fast idle ..should not be over 14.4v.
The last time I checked my battery voltage I did it at the charging points under the bonnet. I was getting 13.1V with engine off and 15.2V with engine running |
This is all rubbish about winter driving running the battery down . All the items mentioned are run from the alternator and the starting load is replaced within 1 minute
| All times are GMT |
