![]() | Home > Maintenance & Modifications > Tow-hitch problem - replacing key barrel |
2 RRS Member Since: 04 Sep 2016 Location: Shropshire Posts: 226 ![]() ![]() ![]() |
You need to knock out the roll pin passing through the handle, it will then pull away with the barrel as one unit.
andrew kennedy Member Since: 27 Apr 2010 Location: brittany Posts: 344 ![]() ![]() ![]() |
Many thanks.......that did help.....job done. Andrew Andrew Kennedy |
