![]() | Home > General (L494) > Two Post Ramp Procedure |
Pistnbroke Member Since: 22 Sep 2020 Location: rugby Posts: 471 ![]() ![]() ![]() |
Position it about 50/50 each side of the posts then you need the post arms extended to go under the chassis as far apart as practical and then use the supplied blocks between the arms and chassis so that it lifts level, ie the 4 lift points contacting the chassis at the same time as it lifts. make sure its rated for 2.5 tonnes plus. Always listen to old people or when they die you will live on in ignorance.
scrumps Member Since: 01 Aug 2011 Location: Somerset Posts: 586 ![]() ![]() |
Hi,
Disco_Mikey Member Since: 08 Apr 2012 Location: Dundee, Scotland Posts: 4531 ![]() ![]() ![]() |
Makes no odds ^ |
Red Arrow Member Since: 06 Jun 2017 Location: Scotland Posts: 595 ![]() ![]() |
Thanks Mike , Any advice for removing seized Brembo front caliper pins ???
Twist them before trying to remove, vice grips etc
