Home > Technical > Which ARC module can I use.
Jobe_joe
Hi guys I’m hoping for some advice. I’ve got an Active Roll Control fault on my Range Rover sport 2.7 2005. (Amber body roll light on display)
My gap tool shows U0428-86 invalid data from steering angle sensor. Invalid or missing message.
The gap tool live data for the steering sensor is showing it working fine.. I’ve swopped the sensor and still get the fault. I can clear the fault with the gap tool but it comes back on immediately without touching the steering.
I suspect the ARC module but can’t find a second hand unit with the same serial number. Mine is NNW504024 (oldest version). Has anyone got experience with changing the module and if so do you know which module would be compatible.
Thanks In advance
Post #636805 Tue Oct 24 2023 6:00pm
NoExpert
Have you tried the install new module procedure on the steering angle sensor?
Next look at live data from the accelerometers. 2011 RRS HSE Luxury 3.0 TDV6 Fuji White on Ebony/Ivory
Post #636806 Tue Oct 24 2023 6:42pm
Jobe_joe
I’ve calibrated the steering sensors centrally and checked they don’t go past 580 degrees each way
Post #636807 Tue Oct 24 2023 6:53pm
NoExpert
Try the install new module procedure. I’ve had multiple calibrations fail and then done the install new module procedure (reinstalls the software) and it works fine. 2011 RRS HSE Luxury 3.0 TDV6 Fuji White on Ebony/Ivory
Post #636819 Wed Oct 25 2023 3:21am
Jobe_joe
There is no install new steering angle sensor feature on the GAP IITool, just a calibration feature. I have since tried to recalibrate the ARC module which failed and has caused a red fault light, C1A00-54 (AF) due to ARCM missing calibration.
The Guys at Gap-Diagnostics have said the ARC module is refusing commands and cant be calibrated until the Steering sensor Fault is sorted
I can calibrate the Steering angle sensor (only faults when engine running) and the live data is fine and shows the sensor working smoothly. There is continuity and no damage on the earth wire, power wire or communication/network wires to the ARC module.
The Alternator charging voltage is just over 15 volts, I have ordered a new alternator to rule it out.
Post #637011 Wed Nov 01 2023 3:29pm
