Home > General > Sudden loss of power but no codes or EML (L320 TDV8)
RobIpswichUK
Looking for next steps on troubleshooting a problem. Was accelerating hard today and suddenly no power. Car still seems to run fine, no noticeable smoke, and no codes. Symptoms are lack of power. Have removed and checked both top boost hoses on the intercooler and looked fine.
Where would you look next?
Post #636137 Mon Sep 25 2023 8:37pm
Pufftmw
Based on recent experience, turbo actuator
Post #636139 Mon Sep 25 2023 8:48pm
TheWojtek
Based on my experience and collective wisdom od the forums, I believe a sticking turbo actuator would throw a P132 and "Restricted Performance" message on the drivers' display. However a hairline split on the manifold, intercooler or hoses would fit the original description. Regards etc.,
Wojtek
WAS: 2006 RRS Supercharged
IS: 2010 RRS TDV8 HSE
Post #636144 Mon Sep 25 2023 9:13pm
Pufftmw
Interesting Woj
My TDV6 is sometimes sluggish at footdown but doesn't always throw that message. It does sometimes
Post #636146 Mon Sep 25 2023 9:29pm
camel_landy
Re: Sudden loss of power but no codes or EML (L320 TDV8)
Sorry to say those were the symptoms when my turbos went.
There was a little 'pop', followed by no power but no warning lights.
M
Post #636150 Mon Sep 25 2023 10:05pm
TheWojtek
I have a recurring "Restricted performance" issue sometimes and it is the left (pass side in the UK) turbo actuator sticking - the relevant code is always stored if this happens and I am always greeted with the red triangle, usually in the middle of passing a truck.
I think it happens when I suddenly demand too much from the car, like queuing behind the said truck at 40 mph for 5 minutes in 5th or 6th and then downshifting and flooring it. That said it happened to me also at 80 mph when I pushed for a high-speed run in Germany.
Funny thing, the car sounds insane when this occurs, like if all the mufflers have been removed (I assume the turbo vanes are stuck wide open). It is always resolved with a power cycle when the actuator is reset.
By the words of my indy, spraying it with grease or WD40 from the outside will not cure it, as it is the soot deposited in the inside of the hot side of the turbo that makes the vanes stick. Tried a 'turbo cleaner' fuel additive with (supposedly) cerium oxide but can't say if it was placebo or did it really help. What does help though is IMHO some more spirited driving, Italian tuneup style. If someone devised a method to clean the hot side of the turbo without removing it (and lifting the body off) with the chemicals LRTime used to clean his turbo in the bucket, I'd be the first to try. Regards etc.,
Wojtek
Post #636157 Tue Sep 26 2023 8:32am
RobIpswichUK
Right so today was having a look, still no EML, but now have 6 current codes:
U0405 Invalid data received from speed control module
P0089 Fuel pressure regulator performance
P065E Intake manifold tuning valve bank 1
P023D Manifold absolute pressure - turbocharger/supercharger boost sensor A correlation
P010F Mass or volume air flow senor A/B correlation
P010C Mass or volume air flow B - circuit low
Any thoughts whilst I start looking them all up?
Post #636159 Tue Sep 26 2023 10:10am
TheWojtek
P023D says your turbo output didn't meet the engine demand, however the P010's indicate a discrepancy in sensor readings, as if some air has been "lost" in calculations. I think the turbos not giving equal output (P010F) happens because of P023D (sticky actuator?) but don't know if P010C calls for a new sensor? Regards etc.,
Wojtek
Post #636161 Tue Sep 26 2023 10:25am
RobIpswichUK
So, an update!
Had the hoses off (no leaks or splits), checked the actuators (all moving freely), runs really nicely with hoses off, but airflow from top of intercooler when running (with hoses off) - no airflow from passenger side but loads from drivers side. Not sure but guessing that points to passenger side turbo not spinning, so turbo failure?
Post #636223 Fri Sep 29 2023 3:53pm
