![]() | Home > Technical > Wire feed ..engine side to glove box fuse box ( routing) |
Col Member Since: 02 Sep 2012 Location: Hawkes Bay NZ Posts: 5134 ![]() ![]() ![]() |
If you look at the bulkhead to the right of the brake servo you will see a grommet about 30mm diam. admittedly opposite side to the fuse box but quite easy to get to and thread a wire over the top of the trans. tunnel, I used it recently.
Pistnbroke Member Since: 22 Sep 2020 Location: rugby Posts: 466 ![]() ![]() ![]() |
Perfect..I was going to get my head torch out and look for something similar ....now I could get my oil pressure gauge feed through that !! Progress. Always listen to old people or when they die you will live on in ignorance.
